ok just obught the carb for central 50 i wantto get an...
    Ok I want to get a performer elbrock intake but does that have egr? and now ingintion is the next question how do i do it i saw a set up with an 74 f100 disbutor and converting to a electoinc inginton but hhow do i adjust timing i m looing for a cheap and easyiest way to do it so guys throw it at me
    Get the 83 mustang GT stick shift (4bbl) distributor.
    Then, you can use most of your duraspark shit, I think.
      Any DII 302 distributor will work. Or if you have a points distributor, you can put a pertronics module in it.
      Find yourself a "Blue" box to replace your "Brown" box and you are set.
        I did the '74 f100 disty, save yourself some trouble and go duraspark II, I'm still having problems with my distributor
          Ok guys I m a novice at this stuff so what brown box and blue box and what is DII 302 distributor talk me threw thing if u dont mind im quick but not quicker than the whip
            This???http://cgi.ebay.com/ebaymotors/MSD-8...QQcmdZViewItem
              Originally posted by 83countrysquire
              This]
              That there is your basic Blue box and a cobbled wiring job of adding a rev limiter.
                And the other thing is a DuraSpark II distributor. Avoid the cobblejob rev limiter crap. And fark those points distributors. By the time you spend the money on the distributor and convert it to electronic you can just buy an electronic distributor that uses commonly avaliable parts vs special mail-order stuff that you'll have to wait for should something fail.
                  you can go with a hei distributor for a 302.......that's probably the easiest and the cheapest route
                    You just need to make sure you get the right gear on the HEI distributor. Someone elaborate, I forget the specifics.
                    Roller cam = iron gear?
                    '85 2-Door Crown Victoria
                    302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
                    '04 Crown Victoria LX Sport, '02 Jeep Liberty
                    '83 Suzuki GS 1100E Motorcycle[/color]
                      Actually, the roller requires the steel gear...
                        GM HEI ignition is nice. One wire. Done. I'd really consider one for a carb motor, especially for the sheer cleanliness factor. No wiring or ignition coil to place.
                        I also forget which uses what gear but roller and non-roller use a different gear.
                            MSD boxes are quick and easy to hook up too. Another route to go if you want. Summit always has some kind of sale on 6al and 6a boxes
                              Yah, that's why I had the question mark. Roller, steel - non-roller, iron.
