I was bored this morning so I yanked off the upper intake and swapped in my old 14lb injectors to see what would happen with an otherwise stock HO engine. The result was eh, nothing. lol The car can't manage to idle for more than a few seconds and I didnt even bother leaving the driveway. So onto gears for a extra mile or two per gallon.
Injector Experiment
You need the extra air to need the extra fuel 19's would deliver. In addition, the ECM program is written with 19# pulse width in mind, not 14#, so as Tom mentioned, it'll run like turds.
'85 2-Door Crown Victoria
302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
'04 Crown Victoria LX Sport, '02 Jeep Liberty
'83 Suzuki GS 1100E Motorcycle[/color]
nitroracer, sorry to hijack the thread.
What about the mid HO conversion? Are 19 lb. injectors required when you do the intake, throttle body and EGR spacer or should I stick with the 14's?
'90 Mercury Grand Marquis GS
5.4L swap coming soon.
NA, i can answer for you. you dont need to switch to the 19 lb injectors if youre just doing the HO upper intake, TB and all that. i think the only time you have to go to the bigger injectors is if you use an HO cam and computer. look here http://www.grandmarq.net/vb/showthre...er+gains+basic
scroll down to 88grandmarq's post and see what he says. there is somebody else on here that is running a "mid-ho' conversion, but i think he has the e7 heads also plus intake and TB. i think his car was in a wreck or something though..... sorry im not sure who it is, i just remember seeing that he did that mid-ho.
You have to use injectors that match the perameters input into the computer.
If you use the 5.0 HO computer with the 5.0 the injector wires need to be changed at the computer connection. I think its 3 and 7 ..... 4 and 6.
With the 5.0HO cam and computer nothing needs to be done with the injector leedss but somme otheree wires need changed or added if your switching to Mass Air. I would have to look up some stuff to be shure of what.Scars are tatoos of the fearless
The wires do not need to be changed when doing an HO swap. Just change the ECM. No wiring changes needed.
Only time you need those 19 lb injectors is with the HO cam/ECM. You can run e7 heads on a lopo with the original cam and ecm, and it runs fine with 14 lb injectors. It would probably be more ideal with standard 14 lb injectors and just a smidge more fuel pressure to get a little extra fuel into the mix.86 Lincoln Town Car (Galactica).
I did the Intake/TB upgrade on my old lopo and got great results. I ran 16.03 with a stock lopo longblock with the HO upper, TB, and bored out EGR. 14lb injectors..
Mixing ECM's and Injectors is a bad idea...I already tried it years ago. Doesn't work.....Builder/Owner of Badass Panther Wagons
The cam dosent matter which injectors you run I have run both cams with the GM ECM and both cams with the HO ECM. The GM ECM is programed for 14# injectors. The HO is programed for 19# injectors. I have injector spec charts for Fords and there are no other ones that swap.
My blue Merc ran the HO TB, 19# injectors, GM cam, HO ECM with Mass Air, modified Merc upper intake and EGR spacer.Scars are tatoos of the fearless
