How do you replace the damn thing? I think mine is getting sticky so I bought a new 97*F one, went to change it today and realized the bottom bolt of the housing is so nicely tucked behind the waterpump - how do I go for it without pulling the air intakes plenums or the waterpump out?
Thermostat...
It's a bitch, but it can be done with a socket. Maybe someone else has a better tecnique.Project \"Fire and Ice\":
1989 LTC
My worst enemies are those who presume me to be harmless. They cannot imagine how much I resent and disdain them, or just how great a threat they would face if I could get at them. Everything in their behavior speaks of insult and presumptuousness, and for now it is all I can do to make constructive use of my anger toward them. At this time, I just make a list of them and keep a watch on. Some day, with the help of time, space, and circumstance, I will be able to humiliate them properly - not in a manner they would enjoy, but in a style calculated to make them wish that they had never been born.
Anton Szandor LaVey
What abotu using a socket head cap screw? Then you can use a ball-end hex key to remove it. That or build a 351.http://secondhandracing.com/Home.aspx
my ratchet wrenches have flexheads.......would reccomend yhe ones with the reversible lever
I got a set of those recently, oh mah gawd they rock!!!
You can do it with a regular boxed end wrench too, if you have the patience of a buddhist monk
do I see a bleed valve in your water pump??? kewlPete ::::>>> resident LED addict and CFI defector LED bulb replacements
After having done this a few times, may I suggest that you unhook the small hose in the way. This will give you more room....and, if you want to buy a tool for the job, buy a ratchet wrench that will fit the bolt. This shortened the time for this chore considerably.
