My car still isn't running right. Still hard to start and runs different all the time. Generally it changes the idle alot, shudders a little bit when coming to a stop and at different rpm ranges, and sometimes randomly the idle will start surging at a light. It also sometimes idles and bogs down to the point of almost stalling out. The car starts to runs better sometimes when its been running for a while though, the problems noted are really bad when the engine is cold. Gas mileage is still really bad, I average 9 mpg in the city.
I've replaced the egr valve, egr position sensor, and egr solenoid which all failed, resulting in code 34. Here's the codes I still get (44,43,44,43,and 49) and thats the order I get them in KOER & KOEO. IAC works fine and the car stalls right away when I unplug it. Both 02 sensors are a week old, I replaced both at the same time I replaced the egr system. Injectors are fine and the fuel filter has been replaced. The plugs were replaced but were white, most likely from the vacumm leaks caused by the egr valve. No new vacumm leaks that I could find, even spent awhile in a family friend's garage with the car running on a lift searching for any leaks I could have missed. No codes for the TPS (did the wot test) eventhough its directly connected to the egr valve.
Yes, I am planning on correcting the timing, I would have fixed it allready but the shop I took it to have it done in January refused to work on my car. They did do it correctly (guy works on and has owned several old panthers) then as the car ran great for awhile, just in the last month it started having alot of problems. I bought a good advance timing light, but I don't know if I should replace the TFI module since it was fine after they fixed it. Doesn't usually when the module goes, your car will just stall out or not start randomly?
Also, can I run 14* timing on this motor since I'm going to correct it? I don't expect for this car to be a rocket but a boost in horsepower would be nice.
