5.8 vs 5.0
    5.8 vs 5.0
    Just was curious about the basic diffs b/w the two engines. Performance, etc.
    Thanks
    Here is the trade off.
    302 a little less power, a little more mileage.
    351 a little more power, a little less mileage.
    302 is already Sequential Electronic Fuel Injection.
    351 is normaly carbed
    Other than that about the same.
      351 is heavier, but not sure by how much
        351W is also taller and wider.
        '95 Ford Bronco XL -
        sigpic :rebel:
          Which engine is currently in your car?
          '90 Mercury Grand Marquis GS
          5.4L swap coming soon.
            I want a 351!
            Project \"Fire and Ice\":
            1989 LTC
            My worst enemies are those who presume me to be harmless. They cannot imagine how much I resent and disdain them, or just how great a threat they would face if I could get at them. Everything in their behavior speaks of insult and presumptuousness, and for now it is all I can do to make constructive use of my anger toward them. At this time, I just make a list of them and keep a watch on. Some day, with the help of time, space, and circumstance, I will be able to humiliate them properly - not in a manner they would enjoy, but in a style calculated to make them wish that they had never been born.
            Anton Szandor LaVey
              Not exactly 302 vs. 351. but close enough
              http://www.mustang50magazine.com/tec...18/index3.html
              '80 Town Coupé
                The engines are based on the same block, but have different dimensions.
                The 302 has a 4in bore with a 3in stroke
                The 351 has a 4in bore with a 3.5in stroke
                To accomidate this, the 351 has a taller deck height, therefore making the engine taller and wider
                Generally, 302's are a little less torquey down low, and can spin higher, where 351's are real stump pullers down low, but don't spin up as fast.
                Also, due to the deck height, 351's need a wider lower intake manifold, although some EFI uppers are interchangeable.
                Nick
                88 Colony Park LS
                  A 351 will spin up just as high and as quick. Plus the blocks will take 100+ more HP depending on year.
                    91 LTD, still didn't answer the question. Which motor do you have in your car?
                      Deck heights:
                      302 = 8.2"
                      351 = 9.5"
                      1989 LTC
                      Anton Szandor LaVey
