in 1990 when they redid the dash, did they change the floor pan of the cv/gm's? only asking because i'm going to start work on my console and i've been using the merk as a test fit only because shifty is buried under snow,lol
did the floorpan change
Fllor pans
They changed the floor pans in 1994 IF I remember right.... The seats in my '91 are out of a 1993, ajnd they bolted right in... so the pan should be the same... Tom...
Floor pans....
The floor pans DID NOT change until after 1993.. They are the same... the seats are the same, the carpet stock numbers are the same... in 1994 they changed.... My seats are out of the newer style car.. a 1993 and they bolted right in... no changes to seat tracks etc... If they changed, they would not have bolted right in..... I do not know if there was a different floor pan pre 1990... Tom....
1979-1991 should be the same shit...the body of th car should be exactly the same.
NO! The bolt holes are different after '89 or '90! Seat tracks from an '89 WILL NOT fit in a '91. If you have a '91 or MAYBE a '90...you can use seats with tracks all the way to '97 unless the '98+ is also the same, then all the way up.'89 Ford LTD Crown Vic - '92 Ford F-150 Custom -
'95 Ford Bronco XL -
sigpic :rebel:
are you sure about this?
That's what I was tryin to say!Originally posted by BoxManNO! The bolt holes are different after '89 or '90! Seat tracks from an '89 WILL NOT fit in a '91. If you have a '91 or MAYBE a '90...you can use seats with tracks all the way to '97 unless the '98+ is also the same, then all the way up.
