Anyone able to get a tranny cooler bigger than 7.5"x12.75" without a lot of work?
Tranny Cooler: size?
Do like me - run two flat steel or aluminum bars in front of the A/C condenser (shape them like this "[", then bolt each horizontal end to the radiator support), then run whatever cooler you please. If you install 4 bars like that you can have 2 coolers (one on each side of the center beam), plug them inline with each other and your tranny will never overheat.
i did mine the same way.Originally posted by Ivan DDo like me - run two flat steel or aluminum bars in front of the A/C condenser (shape them like this "[", then bolt each horizontal end to the radiator support), then run whatever cooler you please. If you install 4 bars like that you can have 2 coolers (one on each side of the center beam), plug them inline with each other and your tranny will never overheat.
Since it is black you cant see it, but the tube loops are actually behind the center support, the strips are what support the cooler. ( i was not going to stick thoxe zip-tie type things through my aluminum radiator.)Originally posted by 91 LTDSo the bars let the cooler "clear" the center beam? Cause that's whats in the way right now. Also I have another cooler to the right of the tranny cooler, engine oil?
Since yours is a police package you have a second tranny cooler and a oil cooler. The oil cooler is the one with the big ass fittings on it. IIRC they are -10 and 3/4" NPThttp://secondhandracing.com/Home.aspx
