does removing emission stuff effect the engine
    I was woudering if removing the air pump and cats emission stuff effect the way the 302 runs and does it effect the computer?
    mine runs good no cats no air pump for about 5000 miles.
      Your computer expects the emissions hardware to be there and is tuned that way. It may run fine without it, but keep that in mind.
      '85 2-Door Crown Victoria
      302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
      '04 Crown Victoria LX Sport, '02 Jeep Liberty
      '83 Suzuki GS 1100E Motorcycle[/color]
        good to know because in maryland I still have to do emissions once 2009 come I dont have to deal with it but do you still have to twick the computer? or mabey I'll just get a new motor in 2009
          mine runs fine without an air pump or cats
            mine runs fine with nothing, no pump, cats, smog solonoids, nothin
              that awsome the engine will still run fine but I still got to keep mine on
              dam maryland emission just last year I had to spend 130.00 on a new egr valve
                id do it, i removed everything as well and the only thing i noticed was more power and a better breathing/ running engine.. there is no delay whatsoever with the throttle now it revs much quicker and sounds insane compared to before plus its much easier to work on since the whole left side of the engine bay is bare.
                i first snipped the belt off, removed smog pump, air conditioning/condenser all the hoses brackets and everything else it took me a little time but it was way worth it.
                  just make sure you plug any vac lines and the smog hose. NOTE i also removed all the ac since it didnt work anyways.. so im sure i noticed it more because of that and the smog not smog alone.
                    everything can come of except for the EGR...I'd leave that on. Cats are good for emissions though...Passing the test. Fast passed with the old car wit honly EGR and cats. No smog pump or air tubes.
                      I've done away with all the emissions BS besides the cats,I'm keeping those because I don't want my exhaust to be that loud.Engine stills runs the same as before only with a slightly better throttle responce.If you decide to disconnect the egr system,leave the egr sensor still connected with the chrome metal rod in the sensor fully extended out,this will make the ecm believe the egr is still there(only allways closed),and that way it won't start acting up.
                        Leave the cats and EGR, dump the smog pump and air pipes. Leave the control solenoids for the diverter valve and cap the lines off. Should cause you no issues. My car passes NJ state dyno test emissions with no trouble with this setup.
                          Does the exhaust smell bad without the cats? I know that clogged or poisoned cats can smell like rotten eggs, so will it smell like that without them at all? And what does it mean when the cats are "poisoned"?
                            smells good with no cats imo. Sorta smells like a lawn mower. Got to a car show/cruise and you'll know what I'm talking about.
                              Dyno numbers to prove this?
                              As for the smell without cats, you will have more unburnt fuel exiting the tailpipes, so it will smell a bit more.
                              ~Adam
