Speedometer accuracy varies with temperature
    Since I got my '85 back on the road, I've noticed strange behavior from the speedometer. In colder temperatures, the speedometer reads about 5 MPH fast, but when warm (~65°F or higher) it'll be generally accurate. The past two days, it'd be off on my way to work and back to normal on my way home.
    Is this potentially a simple lubrication issue? I have to pull the cluster anyway since a light bulb burned out in it.
    I had to remove the speedometer when I replaced the heater core a couple years ago, but I didn't notice any issues for the couple months it still ran after that, so I'm thinking it's from having sat for two years. It has occasionally had the issue where the needle will shoot up to the high end at very low speed, but it's only done that once since I started driving the car every day again - in the past it was just on the first couple drives after being stored for the winter.
    1985 LTD Crown Victoria
    1977 Oldsmobile Cutlass Supreme
    1996 Dodge Ram 1500 4x4, 360
    Past: 1995 Crown Victoria Police Interceptor
    Yeah a through lube and replacement couldn't hurt! See where you are at then.
      The one in the Towncar gets really bouncy and goofy when its cold. Not sure if that one is just cable lube or inside the speedo lube but either way my problem and yours are likely both that the oil is now closer to adhesive than lubricant.
        I've heard some good things about LIQUID BEARINGS (which I believe is a fully synthetic oil) that should not gum up or turn solid in cold temps. Hopefully, someone here can tell us if this is accurate.
          I used red and tacky axle grease thinned (cleaned) with WD40 to lube the speedo head in the 88 MGM I had. Never had an issue after that. I've read that clock oil (for pendulum clocks) works well since it tends to stay in place even though it's thin. I would also suspect that home HVAC fan motor bushing oil would work great as well.
            Thanks - clock oil sounds like a logical choice for a speedometer.
            Where would the oil need to be applied (and perhaps as importantly, are there places to make sure oil doesn't get on)?
              Just the cylinder that the cable goes into. You'll need to get it between the outer (static) and inner (spinning) shell of said cylinder. Don't get it on the plastic gears. I don't think it would damage the plastic gears, but they don't need it.
                I pulled the cluster a couple weekends ago and applied 12 small drops of Horace Whitlock synthetic clock oil.
                DON'T EVER TRY THIS. You will ruin the speedometer.
                After the speedometer settled back down from being removed and reinstalled, there was generally no change. It would peg itself on acceleration more often though, yet it seemed like the accuracy improved with driving in the mornings.
                Earlier this week, I left a stop sign and the speedometer pegged itself, and stayed there at 83 MPH the whole way down a road where I was probably driving 55-60. For the rest of the day, it was reading at least 20 MPH high.
                The past few days it's back to being either 5 over or generally accurate, but the needle wobbles more, and the noise from it is constant now and seems a bit louder than it was when it was only occasional. Warm temperatures don't improve it.
                Given the above-average difficulty in pulling the cluster on these cars, there's no reason not to just send the thing out for repair if you're going to the trouble of removing it. This one unquestionably needs a rebuild now despite the issue having been tolerable before. As expensive as it is, there really isn't an alternative besides hoping a junkyard unit works better.
                  I wouldn't say it's ruined. I would say that the speedometer cable probably needs lubed or replaced. When the needle is bouncing, that usually indicates that the cable is binding and releasing. This could also mean there was some crap in the speedometer cylinder and the oil freed it and once the oil finished cleaning things, it settled back down. I'm not real sure about why it would peg like that unless it was too slippery, but the speedometer isn't ruined if it's within 5mph now. I know the one in the 88 MGM I had needed the needle reset to zero (was reading about 7-10mph low). I had to pull the needle off and hold the speedometer mechanism at the zero position and push the needle back on. It was within 1mph after that until I sold it.
                    I pulled a cluster from an older Ranger once to sell on eBay. The speedometer read way too high. Someone had oiled it with something too slick. I cleaned the oil off with some acetone and it worked fine on the bench after that.
                    A fair number of the 85-mph units are available NOS on eBay. Here's the 82/87: https://ebay.us/m/D1fznU
                      Yeah... I'm thinking 12 was too much. I was thinking maybe 1 or 2 drops would be enough. I'm wagering the excess cleared and it settled down.
