1984 Mercury Grand Marquis vaccum from firewall to hvac panel
    1984 Mercury Grand Marquis 302 my vaccum line from firewall to hvac panel is disconnected. Can anyone send me a picture if its connected to an actuator or hvac control panel please and thank you.
    If you have a loose line from the firewall, it might be the one that goes to the automatic park brake release. If there's no half moon shaped vacuum valve on the bottom of the steering shaft near the firewall, or only one line going from it to the actuator on the parking brake, the black line goes to the smaller barb on the valve. The other line from the firewall should go all the way to the HVAC controls. No line from the firewall should go to a vent actuator from the driver side. On the passenger side, there is a vacuum line for the recirc/vent that will keep the recirc closed if the thermal blower lockout is still working (mounted to the heater hoses just before the heater core and has a pair of vacuum lines going to it).
    If it is the short line that's supposed to go to the brake release valve, you can just plug it if the valve is leaking to get through inspections.
      This vaccum line coming from the firewall.If it goes straight to hvac controls is itbone of the 2 that has no line. Im assuming one of the other ones goes to the middle air actuator.Can find any pictures
      You may only view thumbnails in this gallery. This gallery has 4 photos.
        You may only view thumbnails in this gallery. This gallery has 1 photos.
          This one does have vaccum. For the hvac controls but middle air actuator not connectes no hose loose
            You may only view thumbnails in this gallery. This gallery has 2 photos.
              Found the hoses red and yellow they where under that black box.Tucked away
                I found this blue stripped hose pulling vaccum on max normal and vent.I can't fing a home for it?
                  This one should be going to that one actuator that didn't have a hose on it.
                  That short one from the firewall with that check valve plugged into it is the one for the brake release I'm pretty sure. There shouldn't be a check valve in it and whatever the hose in it goes to is not stock. This should be plugged if it's not needed.
                  those two coming off the top of the box are the ones for the thermal blower lockout (close the vent when engine cold and heater on until heater warms up).
                  The connector you found without any hoses plugged into it should have the entire cluster of HVAC hoses plugged into it. That's the pigtail to the HVAC controls. There should be a bundle of HVAC hoses with the female side of that connector. Without that plugged in, the vents shouldn't be doing anything.
                    Thank you got it going
