You can use coil-over kits to make your rear ride heigth adjustible, up to 6"
This is a coil-over mounting kit.
How to:
First you will have to have some welding done.
you would weld the threaded tube to the center of your lower spring perch. The factory pig tail and coil-over springs share the same diameter 2.5"
Then you install your spring. you can then adjust the new perch up and down till your content. These are available up to 7" high. You do not want to run it all the way u7p because the spring could pop out during long suspension travel.
Im going to run these so that i can use coil-over springs. They are available in a wide range of rates and are reletively cheap.
How to:
