do i need spacers??!?!! [1986 GMQ]
    ok, i test fit the new rims and in the front i think i need spacers. inner rim lip facing the spindle and upper control arm is only like 1/4 - 1/2 inch away, the rim doesn't rub as i spin it but with tires it prolly will. any suggestions on where to get spacers or if there are tires that have a flat enough sidewall that won't stick out further than the lip of the rim?
    Nick
    Test it with a tire on it. If it'll rub, it will be when the steering wheel is turned all the way. If you need spacers, summit racing sells them for $15.00/pair at most. Most tires have a rim protecting lip that sticks them out further than the lip.
    2000 GM LS w/HPP
    K&N FIPK
    Dual Flowmaster 50-series SUV mufflers
    3 & 1/2" rolled, angle cut, polished stainless steel tips
    70mm throttle body from a 5.4L Econoline
    2003 Leather seats with rear cupholder
    2003 Steering wheel w/redundant radio controls
    ADR Spartan triple chrome rims size 19x8.5"
    Falken FK-452 245/40/19 tires
      What car, what wheels? Spacers are cheap, and the small ones can be used without swapping studs.
        Be sure to take into account that the tire will roll over at the top also
        Depending on the height of the side wall, the upper part of the tire can flex like the lower part. On really short tires or tires on wide rims this is not a real big problem, but if you tires are on a narrow rim or have tall sidewalls, they can flex a good amount.
          the rims:
          KEYSTONE - ARE CHROME STEEL 16" x 8" RIMS
          5 BOLT PATTERN: 5 X 4.5
          CENTER HOLE: 3 & 1/4"
          BACK SPACE: 5"
          the car: 1986 grand marquis
          the front rim fits but theres very little clearence between the rim lip and the upper control arm? i drew a diagram with my mad paint skills, lol
          the back rims will also need a spacer if i want to fit anything wider than 225/55/16 which i do, i want to run at least 245's in the rear and 225's up front.
          heres a pic of the back clearence:
          and a pic to give you an idea of what the rims look like:
          helpo me out fellas i know i need spacers but i dunno how to go about getting ones that fit and with studs long enough to work! thanks guys!
          Nick
            Isn't stock backspacing for these cars something like 4.5"?
            I'll agree on checking it with the tires mounted up. If its that tight with just a wheel you might need spacers. If those are the same offset as a Fox chassis (Mustang, etc) wheel, most panthers will need about a 1" spacer to get it back into position.
              iirc the backspacing was 4.25 stock, what size spacer would i need to make these rims work? and where can i find them at that have the correct stud thread and length? thanks again guys i'd be stuck without you!
              edit: will these work???
              Nick
                The factory service manual says that the stock backspacing was:
                Steel = 3.6"
                Turbines = 3.7"
                HO with Explorer Cam, Electric Fan, Cop Sway Bars, Dual exhaust with no mufflers, 15x7" American Racing; 215/70R15's front, 255/60R15's rear, 3.55's with Trak-Lok.
                  well i ordered a set of 4 1" spacers for the merc to get the rims right, that'll do the trick! hopefully be the end of the month beginning of march the car will will be done with rims, tires, and exhaust!
                  Nick
                    Good deal!
                      Nick
                      I woulda sold mine cheap. Beware of the studs/nuts that come with the ebay adapters.
                        how come? they shoddy or something? heres the ones i ordered
                        good or bad? i ordered 2 sets
                        Nick
                          Id buy some Name brand (Milodon, ARP, Moroso, etc.) brand studs and press those in. A set of studs will run about $40, thats cheap insurance to me. The ones that comes in those spacers MIGHT be the cheapest chinese studs they could find.
                            is there any way to tell the brand on the studs? i'll look at them when i get them, i just ordered them today
                            nick
                              You will be able to tell by the lugnuts. Mine were drilled off center and looked horrible. The studs were also too short for my aluminum wheels.
