That rust behind the rear QP trim has spurred more exterior changes... I took all the "granny" trim off becuase i dont really like it and it hid rust... now I have likewise decided to get rid of the black lower rock guards for chrome ones, along with the needed fender well trim to mate them.
Also of course Im going to grind down the little pegs left by the clips from the granny chrome, and use bondo to smooth these and fill the 2 holes left in each door from this trim.
Its starting to get cold here so this part might wait till spring...
So at the yard today I picked up the chrome rockers, some chrome trim for the back window (mine is textured white) and one good peice for a wheel well. The rockers have some rock dings and one dent (dent should be able to be pounded out) but hey you cant beat $2 for the whole lot.
First will be the rock gaurds, then the rear window trim... has anyone done this trim and had trouble with it not snapping back in all the way? i took some off a car at the yard and tried to re-install (for practice) and i couldnt get it all back down... Im skurred!
Ill have to search out the other 3 bits of wheel well trim in good shape (good luck right). I will probably make a trip back up to the yard an hour away becuase I know they have a couple vics in base trim.
. without putting the mercury filler panel on, i took a hacksaw to the plastic trim, to clear the filler panel. any questions, i can answer
