You fancy.
My Ma's 1986 Crown Victoria LX
It's the result of being bored at the tail end of my college years. Having watched a friend pour some money into his Chevelle for seemingly simple tasks; I resolved to learned how to do AN lines. Wish I had learned to do this stuff when I was young.
looks like the main vacuum connection to the manifold.86 Lincoln Town Car (Galactica).
Okay. I found the lopo upper plenum in the corner of the basement. I still have that main vacuum tubing with the branches sticking out of it for other vacuum connections. I will see if I have to use that; or run a new line to it. Thanks guys
I got heater hose for the CV hooked up over the weekend. Came across an issue with the small piece that goes from the water pump to the thermostat. I couldn't bend it 90* without kinking it. I need to find a short (2" - 3") low-tension 5/8" OD spring to insert so I can bend it without kinking it.
Also discovered that my exhaust won't fit the Dynomax 17749 Super Turbo mufflers that I wanted to use. I should have waited before ordering them (8 years ago), but I assumed that I could match the dual exhaust that I had on there. Oh well, I will try to make them work for my '05 MGM exhaust upgrade; it'll just force me to do duals rather than a large single exhaust that I envisioned for that car.
And a pic of the painted steering gear and frame. There is a spot off camera that I have to sand down and repaint; but otherwise, way better than it was. Of course when I was working on the heater hose over the weekend, the freakin trees let loose their pollen pods all over everything, including the exposed engine compartment. I hope it cleans off when I get the rest of the engine together.
Little by little. That’s how progress is made.~David~
Use a molded hose. Not gonna get a 90 degree in straight hose. Its just a 90 degree piece and its very available. Every Ford smallblock used that hose for 50+ years.86 Lincoln Town Car (Galactica).
Not happening with the barb fitting; short length of hose and too rigid to maneuver into the ports. I will have to get the molded piece.
Also got the shorter mufflers last week; they are still too long to install the tailpipes. The outlet almost touches the rear axle tube. I will have to dump the exhaust at the axle and deal with a little extra rumble; well, not me, the driver will happily deal with that.
I bought a molded 5/8" 90* heater hose with 4" legs; which is more than plenty for that tight bend. Installed it on Friday afternoon before the storms hit.
Sinuses sidelined me on Saturday; but on Sunday I installed the turndowns on the mufflers and put up the exhaust. I put it into position and marked the joints for welding. Also extended the ECT sensor plug to reach the new location. Next weekend, when I remove the exhaust, I will put up the driveshaft and remove the IAT sensor from the intake manifold and relocate it to the air intake tube. And if I don't run out of time, I will find a place on the firewall to drill another hole for more wiring.
