Official timeslip thread
This is a sticky topic.
    Sxcpotatoes... A little bit of bad but relevant news... The timer starts when the car leaves the beams so you could have a 5min reaction time or .000 and the timeslip will still say 10.67sec (high 16's 1/4).
    Good news is these cars at these power levels in the 1/4... 7hp drops a tenth, as does losing 90lbs, 10* in air temps=2.5% hp gain/loss.
    Pesty351 that car rips hey! Nice work
      -Did not know that.
      - Are you calling me fat? J/k, I could probably drop almost 90 and pull the spare and jack and fluids from the trunk to have 180 lbs less weight in the car.
