Does anyone know if 17 x 8 cobra rims will fit a 92 grand marquis?
17 x 8 cobra rims
Yep.
You will need spacers (1/4" to 5/16") on the front. That will require longer front wheel studs. MOROSO makes 3" wheel studs that will fit, but you'll have to open up the hub hole slightly. (I'll have to check on the part numbers that I used and the drill size I bought)
It's a bit of work, but the results in looks and handling are well worth it!
RayCar: 2004 Mercury Marauder
Engine/Tranny: 49k miles and bone stock....for now
yes they will fit with spacers...........on the box panthers they will fit too if you use 1" spacers on the front
scott
