I was in my friends 91' Mark VII and noticed her ahstrays lit up. When I looked at the door ashtrays in my 86' Grand Marquis I noticed they have the same slits and semi-clear plastic inserts that would allow me to put some sort of light in the armrest base next to the plastic insert to illuminate the ashtray. Because the location is somewhat small, the heat given off by incandescents, and the draw off adding more lights I wanted to try using LED's. Unfortantely I have no wiring or LED experience at all. Anyone have any ideas as to how I should go about this. My plan is to have one LED for each of the three ashtrays (1 rear driver's armrest, 2 passenger armrest) and I would like to use white LEDS's. Thanks
1986 Grand Marquis LS coupe [/url] http://photos.yahoo.com/leo76830
Id point a 5-led bulb right at it. Heck, even one of the old rounded single LED bulbs might work, since they would focus right on that sqaure. Id get white ones, they are brighter than colored ones, and Im not sure how well the LED light will make it through the lense to illuminate the ashtray. Maybe you could take the lense out? Then ashes may get through it... unless you empty them religiously.
