analog style clock
    analog style clock
    hi i pulled a analog style clock out of a 84 mercury gm at work, and most of them i have seen including the one in my 84 are digital, is the analog style rare or worth anything, because im starting to pull rare parts off cars at the wreckers where i work to sell and make some money to start buying some more stuff for my merc,,
    They're common on older cars. I believe the digital clock was an option.
    '95 Ford Bronco XL -
    sigpic :rebel:
      ok thanks,,
        I have a couple of them, I think I'm going to put one in my '89...just 'cause I can put a blue LED bulb in and change the color to match the rest.
        sigpic :rebel:
          I think the analogs are kinda cool, if I didn't have the tripminder Id throw one in the vic, assuming I could find one.
            ya well ive got one anyone know how much its worth?
              5-10 bucks is all I'd say.
              sigpic :rebel:
                I always loved an analog clock in cars. I'm gonna have to find me one.
                  i was going to put the one i have on here for sale the little knob to change the time dosent work to well you have to play around with it some though, im not sure if it works though beacause i pulled it out of a car from the wreckers where i work
                    If you find a good one let me know. Do they have silver or black faces tho? I'm hoping for silver, it would match the gauges nicely.
                      Black
                      sigpic :rebel:
                        shitty!
                        Maybe I can paint the face silver....
                          I know this thread is a bit old but I figured I'd bring it up since it's the one that came up in search.
                          I don't like the digital clock in the wagon and wanted to know if anyone knows of a direct swap analog clock other than the ones from early boxes that were optional.
                          I have one that fits the opening but would require some slight modification to work.
                            direct bolt in, you're probably not going to find anything other than cv/gm panthers from 79-89 (and as already stated, earlier in the group) that will fit. Anything else will require modifications to fit. The nice thing about the digital clocks, they have metal mounting brackets that can probably be used to help fit whatever other clock in that you want.
                              The idea of an analog clock sounds cool, I would definitely dig one
                              Sent from my SGH-T889 using Tapatalk
                              1987 Grand Marquis LS (GONE!)
                              1990 Grand Marquis GS
                              I like to go fast
