81-84 looked pretty much the same, pointed taillamps and taller pointier front blinkers, CFI 5.0
85-86 had flatter taillights, smaller front blinkers and the waffle grille
85 had CFI, 86 introduced SEFI.
87 had the waterfall grille back with the large hood ornament, rear reflector strip changed to move reverse lights to the outside edges instead of a single light in the center. The aluminum strip is also wider, making the reflector part smaller. Guage clusterfuck style updated.
88 had the small hood ornament
89 got amber front marker lights.
1980-83
lincoln town car
lincoln town coupe (not sure if produced after 1980)
lincoln mark VI coupe
lincoln mark VI sedan
there were no panther continentals.......the fox continental was introduced in 1982
i believe all us models were 302 cfi with eecIII.........i've never seen one with a 351w
1984
lincoln town car
base
executive
signature
cartier
302 cfi eecIV
1985
minor exterior restyling (85-89)
base
executive
signature
cartier
302 cfi eecIV
1986-1989
the efi 302 is introduced in 86
base
executive
signature
cartier
presidential
1990
towncar gets a major facelift......the 302 is retained for 1990
the MARK VI is a diferent generation, all the numbers identify diferent restyles.
