So I did the carb swap. Finally. But for the last 2 weeks, I cannot get the car to run right. Heres what I did:
1. Swapped in Motorcraft 2BBL model 2150 carb from '84 F150 w/AOD
2. 4 PSI External Electric fuel pump
3. 1974 F100 Distributor w/Points
4. Stock coil
The car starts and runs, albiet badly. It will run for about 2 minutes, then die. I can crank on it until the battery dies, it will not restart. I have completely rebuilt this carb, made sure all the passages are clean and free of junk, but I just can't get this thing to run right. I can also press on the gas, and it acts like either the accelorator pump isn't working, or the Vac advance aint working. I checked both, and they are both operational. I keep fucking with the idle mixture needles, but nothing really changes.
Could I have screwed up the timing on the distributor, or is this a fuel problem? I know fuel is getting to the bowl, because after it died, I took the top of the carb off, and the bowl was full. WTF?
There are no vac leaks that I can see, and this thing is really getting on my nerves. I may just buy a new carb, at $388. But it could be something else, so that may be another $388 wasted. Guys, what can I do? Advice? Scott, HEEEEEEELP MEEEEEEE!
4. Stock coil
