'91 GM
My mom took her '91 to the mechanic today and they hooked the computer up to it. The '91 has been cutting out while driving. The code told them it is the EGR valve and/or sensor. I took the valve off tonight and cleaned it up a bit. I found that the gasket was pretty well deteriorated. After I put it together the symptoms have become worse. I'm assuming that the destroyed gasket is at fault. I'm going to toss a new EGR valve, sensor and gasket on, but I have to wait a couple days for the store to get it in.
What I'm wondering is: can anything be damaged with that gasket leak and bad valve? The car is only going to be used for work and back and that's only going to be a total of 50 miles for the two days.
Justin
Justin
