What's a 3ag generator conversion? Donald
some minor rewiring is required.......the regulator plug plugs right in to the 130 amp 3ag. you need to add a heavy wire to the battery with a 80 amp fuse (the stock altenator wiring barely handles the 65 amp altertenator) put a connector on the stator terminal and pluf into the 3ag, and put ring terminals on the other two heavy gauge wires and hook to the output stud on the 3ag.........took me less than an hour btw
heres some pics
scott
Leave a comment:
