for my buddies new to come 87' marquis, can you order a belt just to run the air pump? because, he wants to get rid of the air cond. and the car has to pass the smog test. i know that in 79'-82' A/C was a option. what to do? i hope its not a different pully system!
NO A/C - air pump belt
2011 Ford Crown Victoria Police Interceptor (Down with O.P.P)Tags: None
hmm
you could just ditch the air pump
SuperFord Profile
Support safe sigs
-sigs should not exceed 600 pixels wide
-sigs should not consist of more that 25 lines (including pics) when viewed at 800x600
-Multiple images exceeding 600 pixels wide should have a space between them to allow for wrapping
-Total sig size should not exceed 60k
Remember, only you can prevent sig abuse....
like i said...it has to pass the emition test/smog test/polution test...what ever you call it!
pass the smog test, THEN dump it!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
see, in this country you got to get a emmition test every two years...so this is fucked!what to do?...i need a good answer for this. its not even my car but, still.
dont know off hand what belt to use without the ac compressor..........take a piece of twine, and wrap it around the pulleys as you think it will work, and measure.........convert inches to mm then (ie a 500k6 is 500mm in length)
just use twine while doing the emmisions test, only needs to
just use twine while doing the emmisions test, only needs to last a few min
SuperFord Profile
Support safe sigs
Just measure it, or take the car down to a parts store and start trying belts. When I took my air pump off, I went back to the parts store three times before I got one taht fit.
Actually when I told them what belt I needed, the first thing they asked was if I was removing the A/C compressor. So it's not like it's an un-popular thing to do, surely they'll have a belt in stock that will fit. It just may take a few minutes.
