Results 1 to 11 of 11
Thread: Ugly box wagon tailgate chrome
    Default Ugly box wagon tailgate chrome
    Dear Panthers,
    When I took my 89 CP into the body man to derust a couple spots on the tailgate I said, "Oh yeah. And remove the ugly chrome trim framing the tailgate window."
    But he can't. Turns out, what I thought was chrome is an integral part of two larger pieces framing the tailgate and including some of the (dew wipe ?) (It' helps seal the window). No way to lose the nasty frame.
    So I told him: "Maybe next time."
    What I'd like to know is if any 84-91 big Ford wagon DIDN'T have that frame. If not, I can swap & paint and never be grumpy again.
    Donald
    22,234
    you can paint it, but I think all the big fords had that window trim in one form or another.
    40,275
    yeah they all have it. Paint is your friend. Be careful with that thing, finding good ones is not easy anymore.
    Dear Panthers,
    Grind it down & bondo?
    Donald
    22,234
    If you want to smooth it over, yeah... but I would just sand it since there's not much substance to that trim anyhow and then build up the panel it meets up with to match the trim's level. You'll want to leave the trim as removable as it currently is just in case you need to replace the rubber/felt that's attached to it.
    Southern
    Apr 2013
    Columbia, SC
    922
    You can remove it but you'll need to remove the rivets for the glass. Then you can access the screws/bolts that hold the trim piece , and the piece can come off - but yes that is a dew wipe attached, so...hard to not have it
    -Nick M.
    Columbia, SC
    66 Squire, 89 Colony Park, 90 TC, 03 (2x) TC, 06 TC, 07 TC
    03 BMW 540iT, 04 Ford F150 4.6 XLT Reg cab, 8ft bed
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,797
    You could paint it the body color. Might look good. My 79 was factory painted flat black.
    Dear Panthers,
    I thought about painting it the body color but that'd still be a design element and not much better.You'd still have that odd, skinny oversized window frame.
    Besides, I can remove the tailgate trim but can't w/o doing something with the body trim. It's a puzzleent.
    Donald
    Proud Owner Of A 1987 Mercury Grand Marquis! miamibob's Avatar
    Apr 2011
    South East Florida
    4,478
    Maybe with some photos someone may come up with a good idea???
    Dear Panther,
    I thought to use a stock photo until I realized that the stock wagon images all had wood patterned vinyl which I took off my wagon and the horsey chrome trim worked better with horsey vinyl. So here's the pic: Yeah, I know the spoiler is horsey too but I can fix that.
    Donald
    40,275
    Not entirely sure where the attachment points are on that stuff. You might be able to cut it at the inner chrome strip to narrow it down but retain the sealing bits, but that really depends on how the thing actually hooks to the car. If the mounting bits are in the section that would be cut off, obviously that doesn't work. What I'm thinking would retain the shiny bit closest to the glass only, and the part that is currently tan and the outer, wider part of shiny would go away.
