Page 39 of 41 FirstFirst ... 293738394041 LastLast
Results 761 to 780 of 807
Thread: kishy's 1985 Country Squire
  1. #761
    40,520
    Quote Originally Posted by kishy View Post
    These are "nitrile butadiene rubber (NBR)", which I had determined would probably be suitable before I bought the big kit of them.
    The kit is the combination version of https://www.amazon.ca/gp/product/B07B32WS9K
    I used 5/16 x 1/16 O-rings for this job. I would maybe feel a tiny little bit better about a subtly thicker O-ring, but it's also possible this is the exactly correct size. The hardened ones that came out were not much of a reference point. I'm not sure if they were originally produced to be square-cut, but they sure look like it after 30 years.
    The "H" is hydgogenated. Same thing, but apparently just a smidge more awesome than standard nitrile or something. Mine is the AC O-ring assortment from harbor freight, probably the same thing as that Amazon kit. They sure look the same.
  2. #762
    Stow It! GM_Guy's Avatar
    Sep 2008
    Ontario, Canada
    3,453
    Sounds like a krown location that is doing it by just riding on the name. No matter who it is, I take out my own tail lights & housings. Pretty much most of these places use seasonal extra help, and the drill driver is their choice of screwdriver... Not exactly fragile plastic lens friendly. I take out my own taillights and housings out of the truck when I bring it in. Gets me a few strange looks every time except from the fulltime employees.
  3. #763
    Sep 2014
    Warren, MI
    6,439
    Yeah, now I just tell them to leave 'em in. Part of what I do when I get them home. If I had compressed air and a lift, I think I would do it all myself.
  4. #764
    all the CFI are belong to me
    Feb 2014
    Windsor, ON, Canada
    2,026
    Trans cooler has been trouble-free, and the O-rings in the factory disconnects seem to be holding up. This car does have a characteristic "hot oil" smell but I think that's the many engine oil leaks rather than ATF.
    I decided today to dig into some of the tailgate woes. Those are:
    1. The upper right latch does not latch.
    2. The door handle still works after locking the tailgate.
    3. The power lock actuator is dead (I disconnected the rod when I got the car).
    4. The power window interlock is broken; it is possible to operate the window with the tailgate in positions that I believe are supposed to lock out the power window.
    I quickly found that 1 and 2 are the same issue. There is a cam mechanism in the latch which depends on engagement of a second lever, and that second lever was stuck in the unlatched position, preventing the latch from grabbing the striker bolt and also preventing the lock from engaging with the mechanism. The design of the latch seems to be such that it is not possible to lock the tailgate while it is open, so the latch has to be engaged with the striker bolt and then the lock is able to act on it.
    Soaked that in penetrating oil and exercised it by hand, it easily began working as it should again. 1 and 2 resolved.
    However, after doing that, a new issue was revealed: when the tailgate is closed (the upper right latch is latched), the lock cylinder is no longer able to roll the window up, only down. Opening the tailgate restored this functionality.
    I discovered that a worn piece of the latch - which is a very complicated assembly - was introducing slop. It's hard to describe but essentially it was causing parts of the mechanism not to hit their travel limit soon enough, which caused parts that acted on those parts to never reach the necessary positions to operate the power window switch.
    The offending part is a small pin or peg in the latch assembly which is no longer mounted firmly; its "smushed rivet head" method of mounting has gotten sloppy and the peg doesn't firmly keep things where they belong anymore.
    It can likely be repaired with a tiny tack weld, or perhaps rebuilt replacing the peg with a bolt. I installed a junkyard latch that I had on-hand, which has the same issue developing but isn't as bad yet. This still did not fix the problem until I altered the geometry of the lock rod system by bending it. I expect the problem will develop again over time.
    Fixing #3 was easy; installed a new lock actuator. It now works as expected. I put heat shrink tubing on the manual lock knob rod so it would be quieter as it rattles around in there. I still do not have a good tailgate door card.
    #4 is not easily repairable. I didn't get a good handle on how it actually works, but there is a normally closed button switch (D2AB-14743-AA) that mounts to the latch assembly. The switch body is broken causing it to dangle loosely. If the button is pushed in, the power window is inoperative. I don't see this being a priority to fix but it could be fixed with careful application of epoxy I think.
    Current: 83 GM 2dr POTM 10/2019 | 84 TC POTM 1/2017 & 4/2019 | 85 CS | 85 Ranger +trlr | 86 GM | 91 GM POTM 12/2017
    Gone: 97 CV | 83 TC
    Junkyards
  5. #765
    40,520
    That gate is indeed a complicated mess, everything has to be just so or it doesn't work right
  6. #766
    Feb 2014
    Windsor, ON, Canada
    2,026
    Alright. So if I use the power lock to lock the tailgate, it doesn't lock. It gets alllllllmost locked, but doesn't pull just that tiny little bit more that it needs, and won't engage. I think if I were to flip the power lock and manual lock rod connections it would give the actuator more leverage and work better, but I haven't studied it too close. The key consistently locks it every time, it's just a linkage geometry issue.
    Also, the window only occasionally works with the key, in either direction. Very irritating. I may apply power to the spare tailgate (I have a complete spare one) and see if it behaves better. I don't really want to put the mismatched tailgate on but having this work would be nice.
    I received one of my packages from China, and am pleased with what it is enabling me to do: https://www.youtube.com/watch?v=AzfY7e4UkCc
    Not implemented in the car yet, but soooooooooon...
    Gone: 97 CV | 83 TC
    Junkyards
  7. #767
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,942
    That is pretty cool. I never seen a wagon modified with those type of turn signals. I also like the back up light switching from clear to red.
    Hope the Made in China stuff is durable.
  8. #768
    Mar 2006
    Bedford, VA
    6,361
    I despise working on the tailgate stuff. I had to do a hinge rebuild and latch adjustment on my 88 back when I was twenty and had more patience for such things. It's like throwing five dice on the ground and trying to get them all to read the same.
    LED's are nifty. I suppose one could do an amber/white switchback for those countries which require the amber turn signal.
  9. #769
    Feb 2014
    Windsor, ON, Canada
    2,026
    A handful of us have done sequential turn signals on Mercury sedans, because it's just such an obvious thing to do with those tail lights. That one guy did sequential front turn signals on his Ford wagon...I decided to do the rears instead. Of course, it all hinged on being able to get my hands on a red/white switchback LED bulb.
    This is my second attempt with this. The first set of red/white switchbacks I bought did not behave as desired; the white illuminated immediately but the red was delayed by just long enough that the sequencing did not look right. This second set of switchbacks behaves as desired (instant-on for both colours). Both the troublesome ones and these ones are advertised as being for 2015 and up Mustangs and the Chevy Volt (and similar sorts of vehicles) to enable you to mod them to have a rear fog light combined with the reverse light.
    These are the ones that do not behave as-desired: https://www.aliexpress.com/item/32814612998.html and https://www.aliexpress.com/item/4000041535899.html
    These are the ones that do behave as-desired: https://www.aliexpress.com/item/4000106102890.html
    I also have two other variants still in the mail because I got a little click-happy with the buy button. I will test them for suitability as well.
    Amber/white switchbacks are significantly more common so absolutely, if someone wanted an amber turn signal in the reverse light housing while retaining functioning reverse lights, that's a good way to do it.
    I think I'm going to hide a small incandescent bulb somewhere still wired into the brake light circuit, so my cruise control will work. Preferably I'd get some sort of centre brake light that I like, but I find the proper Ford one for 86-91 wagons kind of bad looking, so I'm not sure if I want to go that route with it.
    Gone: 97 CV | 83 TC
    Junkyards
  10. #770
    Nov 2012
    Shelby Township, MI
    3,568
    I was thinking the exact same thing, LOL.
    Very nice mod by the way.
    Still waiting on the border to open. Would be cool to do another Detroit/Windsor meet. Will asked me if we were doing another meet and I told ComputerFreek to keep an eye on the forum.
    ~ 1991 Mercury Grand Marquis LS "The Scab" - plenty of rot, backup/summer cruiser
    ~ 1997 GMC Yukon SLT - wannabe winter DD - many issues, returning sometime in the 2020s
    Gone but not forgotten:
  11. #771
    Sep 2014
    Warren, MI
    6,439
    I'm down for another meet. Maybe I'll bring the Lincoln and Ash will bring the van.
  12. #772
    Sep 2008
    Whitestone, NY
    20,191
    Amazing job. Those will look great on the wagon.
  13. #773
    Feb 2014
    Windsor, ON, Canada
    2,026
    +1 down for a meet once travel is unrestricted again. The major hangup is the requirement to isolate upon return and as I have continued working (in the office/at the workplace) steadily through all of this, that is obviously not an option.
    Very excited about the sequential signals. Hoping to get that wired up in the car ASAP.
    The tailgate window motor gear finally let go. What an inconvenient thing to repair...I pulled a motor out of the parts stock, verified it was in good shape, tossed that in and all is happy. The motor I used is the "newer style" motor, however it came out of a Fox something-or-other, maybe a Mark VII. As sort of expected, the third screw hole was not aligned, but 2 screws is probably fine for these anyway. Of course I mis-drilled the first access hole too, but on this tailgate (significant rust damage) I'm not too bothered by it.
    I relocated the mount point of the tailgate lock actuator to be about a quarter inch lower than original, and this seems to have significantly helped both the power lock functionality as well as the lock cylinder actuating the window switch. I think the actuator was reaching minimum travel before the mechanism was fully engaged, which I have now corrected.
    Gone: 97 CV | 83 TC
    Junkyards
  14. #774
    Feb 2014
    Windsor, ON, Canada
    2,026
    Blegh, I really dislike making wiring mods this permanent, but there just wasn't a friendly way to make it somehow be unpluggable and not still a big mess. The result is good though!
    Now installed and functioning:
    - WebElectric STS-1 turn signal sequencer modules (not wired with the optional control wires - may add them later)
    - Gtinthebox (via AliExpress from China) red/white switchback LED bulb replacements
    - Tekonsha Tow Ready 119147 trailer light power module (a combined module that relays all the trailer lights, not related to the turn signal mod but done at same time)
    Stock on left, modified on right: https://www.youtube.com/watch?v=lhsUQ4oe_qE
    Mod complete: https://www.youtube.com/watch?v=8WYCSQgVVFU
    Not really going to do a step-by-step here, it's straightforward if wiring comes naturally to you...the red/white switchbacks are a critical component for the following reasons:
    - Sequencing lights with only two segments are Less Cool™. It is a scientific fact.
    - Making the reverse light act as a brake/turn lamp adds additional lighting surface area which should increase safety and visibility.
    - Between aging housing and the inherent properties of LED retrofit bulbs, the intensity of the low/high brightness change is not always as obvious as it should be, so more light is better.
    - Having the reverse lights remain functional as reverse lights means no need to stick additional lights on the car to keep their function.
    Bonus, it seems the Tekonsha module fixes the problem where 1) LED-only tail light bulbs will glow gently on the brake light circuit due to the workings of the cruise module and 2) cruise does not work when using LED-only bulbs on the brake light circuit. I can only imagine this is because the Tekonsha module contains a relay coil on each side brake/turn circuit, and the relay coil is serving the function of letting the tiny sensing voltage flow where it needs to go. I had been prepared to add in a load resistor but it did not end up being needed, seemingly due to the Tekonsha module.
    I ran a 14ga (I'd have preferred 12 but didn't have any) from battery positive, through a fuse, all the way through the car to the back to get power to the module. My trailer has all LED lighting, but in the event I tow something with incandescent lighting, I will now feel less concerned about that current coming through my crusty factory harness and instead coming through the new 14ga wire with 15 amp fuse. Not to mention a trailer wiring fault is no longer capable of doing something stupid like burning a fuse link in the car. Thanks to 87gtvic for the pointer on that module, it's cleaner (or at least more convenient) than trying to put a block of individual relays. Not serviceable if a relay inside fails, but that's a risk worth taking in this case in my opinion.
    Gone: 97 CV | 83 TC
    Junkyards
  15. #775
    40,520
    yep, coil completes the path to ground and the cruise servo is happy. I really think thats an incredibly stupid way of doing it, looking for loss of ground vs looking for positive voltage, but whatever.
  16. #776
    Sep 2008
    Whitestone, NY
    20,191
    Looking really good.
  17. #777
    Sep 2014
    Warren, MI
    6,439
    I'll be the dissenter here, seems strange when done vertically as opposed to the traditional horizontal style where the lights sequence in the desired direction.
  18. #778
    I post a lot... mitymerc's Avatar
    Nov 2005
    2,619
    May be strange, but way more visible than the old factory stuff.
    Plus unique is good
  19. #779
    Sep 2008
    Whitestone, NY
    20,191
    I am noticing more and more vehicles that have brake lights that flash for the first few seconds. I like what you did.
  20. #780
    Feb 2014
    Windsor, ON, Canada
    2,026
    Counterpoint: "traditional sequencing" could be considered dangerously unclear as to the driver's intentions. Consider the use of traffic advisor devices on emergency and utility vehicles, which functionally resemble a sequencing turn signal. The lights flash towards the direction that they want you to move your vehicle so as to pass the vehicle with the blinking lights on it. Consider the even more troubling scenario where a vehicle with a traffic advisor is wired so that it acts as a sequencing turn signal when it is not turned on to direct traffic (and there are builders who wire vehicles in this way). We could dissect this topic for a while. Has this ever been tried in court? Could be very interesting if some idiot out there passes a car with factory-equipped sequencing turn signals on the side which the signaling vehicle is turning towards, causing a collision. It would not take a top dollar lawyer to rip apart the function of sequencing turn signals because of the use of similar light patterns for very different purposes.
    I had considered an option where I lined the housing with LED-laden PCBs, wired into 3 circuit segments, so that the lights could sequence inboard-to-outboard. Ultimately I decided to do this instead because I felt it would be more obvious, and a mod to critical safety equipment should increase its visibility, not risk making it more obscure. A couple reviews from friends who've driven behind me now confirm that I have dramatically more obvious brake lights than I had before, and I've noticed that I have less nose-diving late brakers behind me, which is always a problem I notice when driving things without third brake lights.
    I would recommend the red/white switchback brake light mod for the reverse lights (minus the sequencing) to anyone with a vehicle that lends itself to it well, e.g. the reverse lights are grouped with the tail lights, and located outboard, which would cover Ford and Mercury wagons, and Ford sedans among our cars (and maybe kinda sorta the 88-89 Lincolns, but they might look funny). 85 Town Cars (specifically 85 because no third brake light) would essentially gain a third brake light doing this mod to them, given the centre mounted reverse light. Mercury wagons are sorely lacking in brake light surface area and would likely benefit dramatically. I've now bought a handful more of the specific confirmed-good LED bulb product so I'll have spares on hand, re: the fact that I tried others which do not behave as desired so these could potentially get hard to find at some point in the future, or they could make a production change that makes new ones of the same no longer behave as desired.
    Gone: 97 CV | 83 TC
    Junkyards
