Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: 88-91 MGM side trim clips
  1. #21
    Mar 2010
    Lewisville, TX
    22,226
    Right. New users must manually set the setting. Click settings at top, then click General Settings in the left menu. Scroll down to Private Messaging and the last setting in that section is save or don't save sent message. make sure save is marked and then scroll down to the bottom of the page and click Save Changes.
  2. #22
    Member
    Jun 2011
    Metro Detroit, MI
    31
    That makes sense. Probably saves a boat load in storage for the hosting. As long as the message sent - that's all I care about, lol. Once I get the trim and her first wax. I will post before and after photos of my old girl. Figured I will "complete" her before doing a full show and tell. *I will start a new thread for that, obviously.
  3. #23
    Nov 2012
    Shelby Township, MI
    3,474
    We can definitely work something out. 7 will get you further than none.
    ~ 1997 GMC Yukon - wannabe winter DD - returning sometime in the 2020s, I finally have an engine
    Gone but not forgotten:
  4. #24
    Mar 2010
    Lewisville, TX
    22,226
    Cad file in hand. Used Freecad to fix some internal duplication on the file and clean up the mesh.
    File is HUGE - 67MB. If you want to try to work with it, leech here: http://www.grandmarq.net/sly/Trim%20...0-%20fixed.stl
    If anyone wants to try to clean this up for printing (flat faces and the like) have at it. But we now have a base scan to work with. Also, this STL file should be able to be printed at any local 3D printer house but may require 100+ unit prints depending on the company. Lower prints are more expensive per unit, obviously. Resin printer should have zero problems printing this thing. Anyhoo... have fun folks.
  5. #25
    Nov 2012
    Shelby Township, MI
    3,474
    Nice!
    I'm interested in messing with this, I'll download when I get home.
  6. #26
    Mar 2010
    Lewisville, TX
    22,226
    First print attempt using "eco-abs". Looks workable. Would prefer nylon, but pretty sure nylon won't have the definition on this printer since it won't do as fine of movements and requires more heat. Trying to get freecad to turn the mesh into a shape right now. Single threaded process is slow. Anyhoo... pics...
ID:	56237 Click image for larger version.
ID:	56238 Click image for larger version.
  7. #27
    Mar 2010
    Lewisville, TX
    22,226
    Printed it flat with the spring legs flat on the printing surface and all the support structure under the face of the clip. This one came out better.
ID:	56247 Click image for larger version.
    I'm also trying to get freecad to mesh to shape this thing so I can possibly save it in a much smaller file. It's a single threaded process though and is taking forever. over 24 hours so far and counting. If someone has access to solidworks or autocad and can use their mesh to part converters, I'm sure they would be MUCH faster.
  8. #28
    Nov 2012
    Shelby Township, MI
    3,474
    I haven't done anything with CAD in about 15 years and that was an introductory course with Unigraphics (now Siemens NX).
    ComputerFreek seems to have some connections that may pan out. We'll see what and his contact comes up with.
  9. #29
    Mar 2010
    Lewisville, TX
    22,226
    Freecad is still working on the one transform. There's just too much data for a single threaded process I think.
