Page 19 of 20 FirstFirst ... 917181920 LastLast
Results 361 to 380 of 392
Thread: My '85 MGM, "Maisa"
  1. #361
    40,538
    basically the vacuum thing fights the spring in the hockey puck. Don't remember the specifics but basically the vacuum thing tries to pull the high idle cam out of contact, but the spring in the hockey puck tries to keep it there when cold. If the vac doesn't work it won't ever pull the high idle cam out of contact.
  2. #362
    Jul 2019
    Finland
    898
    It probably works just as it should, it just seemed that the vacuum pull-off was already bottomed out but it wouldn't pull it off the cam all the way.
    The pull-off shaft won't go in so far as to click it off the lowest step.
Name:	High idle cam.jpg
    It just rests on the little nub that the arrow points at. It had a little bit of pressure on the nub for a while, but when the spring starts warming up the nub eventually moves away from the pull-ff shaft.
  3. #363
    40,538
    sounds right, just tweak the hockey puck if you need it to stay on high idle longer. Since you don't drive it in the winter its really not a major concern.
  4. #364
    Jul 2019
    Finland
    898
    Well, the AC belt shredded itself coming home last night.
    The belts were both old, but dang. Now I have an ugly hole in the hood insulation.
    So that kickstarted the smog pump delete I thought about some time ago. I got both new belts. From the 3g belt size thread I got the idea that removing the smog pump pulley would be enough.
    In my case, the pump casing was hopelessly in the way of the belt, so I took the whole pump and bracket off.
    I routed the belt the "factory" way under the tensioner, since the adjustment slot in the bracket wasn't long enough to have the lower part of the belt go above the tensioner. I did have to remove the positioning bolt to slip the belt on the tensioner pulley.
    Currently the belt bounces around about an inch or so between the crank pulley and AC, I want to get it a bit tighter, but I need to get a stubby 1/2" extension to get a breaker bar properly into the tensioner slot. Also another pair of hands would be great.
    I went with a 1425mm (56,1") belt, if it was a tad longer, it would've been better to route it above the tensioner.
  5. #365
    GMN Regular
    Aug 2018
    750
    I had that bouncing belt issue on my 87 when I first put a compressor on it. I ended up putting a smog pump back onto it just to get the belt to not bounce around or come off. It threw the old belt a few times before I did that. Hopefully you have better luck and can leave the smog pump off.
  6. #366
    https://www.americanmuscle.com/frpp-...E&gclsrc=aw.ds
    Would one of these work on our cars?
  7. #367
    GMN Regular
    Aug 2018
    750
    No, I tried one on my 85 and it didnt work.
  8. #368
    40,538
    I've got an underdrive pulley on mine with no smog pump, and the belt works fine. There isn't a lot of room between the to and from sides but despite winding it out pretty far more than once it has never chucked or eaten a belt. Can't say why your car might not be working, but if its throwing belts I'd be looking at the pulley alignment and for bent or loose brackets. That long smog pump bolt that goes through the plate where the tensioner is probably ought to get re-installed with a piece of pipe to make up the distance of the missing pump. Stock there is a spacer behind the pump, just measure the length of that plus the pump and cut a piece of pipe to that size. Without the bolt (and mine is missing) the bottom of that bracket is not really supported by anything so it could be out of position.
  9. #369
    Jul 2019
    Finland
    898
    For any interested parties:
ID:	56550 Click image for larger version.
    The top smog pump bolt is 5" and 15/16, not including the head of the bolt.
    The spacer piece is 1" and 7/16.
    I don't think the belt bouncing on mine will be an issue, it doesn't jump around too much. I'm 100% sure the AC belt shredded due to it failing from age. The scraps that I ripped out of the engine bay were horribly cracked and hard.
    My crank pulley has a very minor case of the weeble wobbles, the smog pump pulley was worse.
  10. #370
    Jul 2019
    Finland
    898
    I'm thinking of ordering new sensors for the intake air temp and coolant temp, maybe those could help with how the car is running? Mostly the rich idle when hot.
    Also I'm having a rather stupid issue, on hot days the dome light lens keeps falling off.
    Last week and the last few days have been by far the hottest days this summer, and probably last summer too. Last week was around 29C (84f) and the last two days have been 30-34C (86-93f) I'm pretty much suffering unless I'm in an air-conditioned space. Might not sound too awful to some of you, but us Finns weren't designed for this!
  11. #371
    22,395
    Yeah... if those sensors aren't working, it'll act stupid.
    You can test them easy enough.
    Engine coolant temperature sensor: http://www.grandmarq.net/oldfuelinjection/page28.html
    Air charge temperature sensor: http://www.grandmarq.net/oldfuelinjection/page29.html
    As for the temps... I'm good until about +5 of what you're dealing with. Folks up in the northern areas start having heat advisories at -5 of what you're dealing with. We don't get the heat advisories until the "what it feels like" hits triple digits (F).
  12. #372
    Jul 2019
    Finland
    898
    Thanks for the links, should be able to check them out sooner or later.
    In Finland we have 3 stages of heat warnings.
    -Yellow warning (hot) at 27C (80f)
    -Orange warning (very hot) at 30C (86f)
    -Red warning (extremely hot) at 35C (95f)
  13. #373
    22,395
    Generally your orange is the up north level and the red is the down south warning. The difference is the prevalence of AC. The south has AC everywhere. The north... not so much.
  14. #374
    Jul 2019
    Finland
    898
    The IAT and ECT sensors seem to check out.
    I also plugged the EGR back in now that the car has more of it's shit together again. It seems to accentuate the jerky decel, otherwise it doesn't seem to make the car run worse as it used to before.
    The jerky decel is probably the last actual annoyance that this CFI still has.
    On the way home from the quick test drive I caught a gnarly summer storm rolling in:
  15. #375
    40,538
    just for yucks, try plugging off the vacuum line running from the intake to the evap purge valve. Thats the white round thing with 3 hoses on it. One goes to a solenoid, one goes under the battery, and the third goes to the intake someplace. Closing off either of the two that don't go under the battery will make it stop working. I'm just vaguely curious if its opening that and causing it to run lean on decel because of some problem with the evap system.
  16. #376
    Jul 2019
    Finland
    898
    I don't think it made a difference. Kinda running out of things to try out here...
    But I did try unplugging the SPOUT again, and it did help some. It didn't make the jerkiness disappear at all, but seemingly reduced it a bit.
    The timing is supposed to be correctly at 10 BTDC and it has a new-ish double roller timing set, a new TFI unit and reman dizzy.
  17. #377
    GMN Regular
    Aug 2018
    750
    Gadget or Sly you guys would probably know, did the cfi cars use a single common ground for all the under hood sensors like the efi cars did?
    I was thinking op you could drive around with a vacuum gauge installed to see whats going on with vacuum. Or you could even hood it up to the egr valve to see if its getting vacuum while decelerating.
  18. #378
    22,395
    Everything I know I've read here. I would expect it would be common ground, but I don't know for sure.
  19. #379
    40,538
    Most of the sensors are the same on CFI as SEFI, they just screw into the engine block as the ground. There should be a wire somewhere in the ECM harness that connects to the engine so the block and all the sensors screwed into it are at the same ground potential.
  20. #380
    GMN Regular
    Aug 2018
    750
    Unless its been discussed earlier that could be something to look into. 36 year old wires are bound to have a little bit of corrosion on the inside.
