Results 1 to 8 of 8
Thread: Valve covers with TrickFlow
  1. #1
    Jan 2008
    New Jersey
    3,123
    Default Valve covers with TrickFlow
    So I ran into a problem with my engine install. My tall valve covers not only hit the plastic firewall piece on the drivers side, but they hit the A/C compressor. The edges of the TrickFlow head are raised, and I learned I can probably run short valve covers and they will clear the roller rockers, however I will have to remove the baffles to do so. Iíll probably have crazy oil consumption through the PCV if I do this... Iím not sure what to do. I need some ďmediumĒ size covers... any ideas??
    -Phil
    +1982 Ford LTD-S Police Car. 351w, GT40 Heads, Edelbrock 1906 Carb, Full exhaust headers to tails. 3.27 Trac-Lok Rear. Aluminum Police Driveshaft. Speedway Springs+Bilstein Shocks, Intermediate Brakes, Baumann Shift kit.
    Member
    Jun 2006
    Holland,MI
    529
    Spacers exist, but... more gaskets needed. https://www.speedwaymotors.com/Ansen...ers,35302.html
  3. #3
    40,269
    prob have to be looking for stuff designed to fit under a stock EFI upper manifold. All of the carb ones are on the tall side. Cheapest option with a lot of room inside is actually the lopo steel covers. Same ones used on the Cobra actually. If you use a lopo cover on the right side and the Explorer cover with the fill nipple on the left you'd have a fill and air intake on one side and you can figure a way to install a PCV valve in the open nipple on the other side. May have to get creative and make up an internal baffle or something to screen out the oil but you'd at least have a raised area to work with instead of having to get into the rockers.
    and no that won't look sexy at all but it should function.
    I run 85 Mustang covers on mine. Not real tall, and they clear my roller rockers with no internal mods. Maybe that would work? Those were meant to have PCV in the fill cap, and the caps were usually stuffed with coarse stainless wool to act as an oil sep. I'm using it as an air return since my PCV is at the back of the intake.
  4. #4
    Nov 2006
    Dirty Jersey Yo!
    8,338
    I ran into the exact same issue as you. Unfortunately I was given the same options and I opted to cut my wiper box. That was after I had already smashed the wiper motor during the 1st engine install attempt. I didn't have to worry about the AC compressor though. Wouldn't Explorer valve covers with spacers work with those heads and 1.7 ratio rockers? I was thinking of going that route as an alternative.
  5. #5
    40,269
    explorer covers are almost identical to stock lopo ones, except the fill neck is kind of goofy. I'd keep the original ones before swapping to explorer parts unless you had very specific need to.
  6. #6
    Nov 2006
    Dirty Jersey Yo!
    8,338
    So, I should probably put lopo valve covers on my junkyard shopping list.
  7. #7
    Jan 2008
    New Jersey
    3,123
    Some good information, thanks guys.
    I ordered these:_ https://www.ecklers.com/valve-covers...0-17134-1.html
    They should be slightly higher than 85 mustang covers, and have a unique baffle design. If the baffle doesn’t fit I can make my own inside the tube that goes up to the oil fill/PCV area. I’m hoping I can make them work. I will report back
    -Phil
    Nov 2006
    Dirty Jersey Yo!
    8,338
    Those are nice! You can always plumb a catch can as well; if you don't mind emptying it out every once in a while.
