Results 1 to 9 of 9
Thread: Core plug
  1. #1
    Default Core plug
    So this blew out on the passenger side near the starter, obviously coolant has all leaked out, what do u guys recommend? Click image for larger version.
ID:	56135 Click image for larger version.
  2. #2
    I post a lot...
    Dec 2011
    Yonkers NY
    4,292
    That is a block heater.
    Do you want a block heater?
  3. #3
    No, i only drive the car in the summer
  4. #4
    But if its an easier fix, then i'll put a new block heater in. Also should there be something in the threaded hole below it?
  5. #5
    Mar 2010
    Lewisville, TX
    22,235
    The threaded hole below it should be the block drain plug. It's down inside that hole and should be a hex drive plug.
    As for the block heater: clean out the hole and you can take the broken bits of the bolt clamp and get some flat bar about the same length but about 1/8 thick and thread it or weld a nut to it that fits that bolt and put it back in. If there's any rubber seals for the bolt hole or outer edge, you may need to replace those.
    Or just get a casting plug (freeze plug), make sure the surface is dry on the walls of the hole, put some sealer around the plug and knock it in.
  6. #6
    40,275
    problem with the core plugs is that you usually can't drive them in with the engine in the car. Most of the time the angle is wrong. Possibly why someone put the heater in there to begin with, especially if it doesn't have the cord with it.
    Expanding rubber plugs exist for this reason. The block heater looks like the same kind my diesel had, and has the same failure. The "wing" that retains it didn't have a hinge, it was just bent into a V originally and the nut looked basically like a Chevy bow tie. The screw simply pulled the bow tie into the V and flattened it out. Unfortunately that makes the metal at the point of the V flex and it caused a stress crack. Mine failed when I pulled it out to replace the leaking O ring. There is also a rubber washer under the head of the screw, but without that wing none of that matters. It will not hold in the block without it. Not sure if you've got enough screw and depth to get away with a solid piece of steel with a tapped hole or what.
    if you can just replace it with a standard core plug, do it. Clean the hole out real well, wire brush it so its down to clean metal, and hammer the thing in there. I've never used sealer but if you want to, use something thin line aviation sealer. No RTV or anything thick like that. They hammer in with a socket that just fits in the core plug, and they drive in until the edge of the cup is flush with the block. See your other ones for examples.
  7. #7
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,799
    Make sure you use a freeze plug made of the same metal as the others in the car.
    My personal opinion is to stay away from the rubber freeze plugs. I have used them many years ago. Never liked them.
  8. #8
    40,275
    they aren't ideal, but it makes sense if the only other option is to yank the engine to drive in a metal one.
  9. #9
    Mar 2006
    Bedford, VA
    6,255
    Quote Originally Posted by Mainemantom View Post
    I agree with both of these. I am running three rubber ones in my 74 pickup. I don't necessarily like it, but they have been in there and doing the job for about 7 years.
