Results 1 to 7 of 7
Thread: Clicking under dash
    PROUD DADDY OF JILLIAN PICKUP6772's Avatar
    Jun 2005
    MASTIC BEACH, NY
    759
    Default Clicking under dash
    Hey guys,
    Finally got the Town Car back on the road. Now I am having an issue with a rapid clicking under the middle of the dash. I scanned for HVAC, and BCM codes, and have nothing. I know right away,, that is wrong,, as the recirculation motor is missing.. According to my daughter, it sounds like a woodpecker stuck in there. It happens about every 4-5 minutes, and is quite annoying. Does anybody have any ideas.
    Thanks, Mike
    22,317
    What year is the towny again?
    I know my 88 MGM had the autolamp relay there behind the ashtray, but the townies may not have kept it in the same place. I've also heard of the door chime doing stupid stuff and it's mounted somewhere in that area too.
    40,396
    if its new enough to scan, its new enough to have a blend door motor. Bet you a buck its the actuator.
    Jun 2005
    MASTIC BEACH, NY
    759
    Sly, the car is a 2010. Gadget, I was thinking about that, as I replaced the right side one a while back. It is an aftermarket, so it could have crapped out. The car was a freebie from a customer who owns a Limo service. The blend motor, and recirculating motor were both missing, as I'm certain his in house "mechanics" raided it for small parts.
    Mike
    22,317
    Yeah... +1 blend door actuator. You can technically see if behind the glove box, but getting it out... Lots of cussing and possible dash removal. Might be able to get it by pulling the passenger airbag out of the way. The usual cautions about doing that though. Disconnect battery, press brakes... wait another minute or 20... then remove.
    Stow It! GM_Guy's Avatar
    Ontario, Canada
    3,444
    Yes, the airbag definately gotta get out of the way, it completely blocks any access to the area. If you got to pull a whale dash, and you have done a box, the whale is an easier one to do, I find. Don't need to remove it but getting it so you can move it around helps a bunch.
    Jun 2005
    MASTIC BEACH, NY
    759
    Thanks guys. Sorry for the delay in responding. Just finished my last day at my old job. New job starts Monday, with More pay, better health care, retirement, and shorter commute. Win/win/win.
    Mike
