Results 1 to 12 of 12
Thread: which gasket sealant to use for throttle body and spacer?
    Default which gasket sealant to use for throttle body and spacer?
    Good day and hope all of you are well,
    I'm going to swap throttle bodies this weekend.
    Which gasket sealant should I use for the throttle body and spacer?
    I do have new gaskets for the swap.
    I thank you always,
    Mike
    Jan 2008
    New Jersey
    3,147
    I haven't heard of anyone using gasket sealant...but if you want you can't go wrong with the Ultra Black.
    22,394
    +1 dry on a clean and flat surface. If using any RTV, use just a smearing on the gasket surface.
    +1 Ultra gray or Ultra black are the ones to use.
    Thank you again Sly and Brown_muscle.
    40,536
    None. Light use of a file to make sure the surfaces are flat and smooth should be all you need.
    Donating Member
    Oct 2011
    USA
    284
    Never heard of using sealant but I prefer the “right stuff” for these things.
    RTV usually has a cure time, the “right stuff” requires almost none.
    YMMV
    Birdsboro PA.
    17,699
    don't use rtv on those gaskets, just make sure all surfaces are flat and clean.
    Thank you Scott and Massacre.
    I will not use any sealant and will clean the surfaces will.
    Thank you
    Member tbear853's Avatar
    Jan 2021
    Virginia but I started life in Texas
    97
    Carb base gaskets and throttle body gaskets, not O-rings, get a thin smearing of grease here. Never had one leak and no pealing either, the grease gets absorbed and swells it in time I guess. Old tip from way back!
    Thank you Gadget.
    Got the 65 mm throttle body and spacer on. I used no sealant.
    I drove 10 miles and it was a blast.
    I noticed the engine seemed to breath easier. Maybe the gas mileage will improve to.
    Less effort on the gas pedal or so it seems.
    The throttle body came with a new TPS and I also put a new IAC on. This all was so easy.
    Today I'm going to check the voltage on the TPS at WOT and see if it is correct.
    You know the saying .
    If it ain't broke, don't fix it.
    MAF 75 mm Pro M
    65 mm Explorer TB, 65 mm spacer
    68 mm mm GT 40 intake opening.
    19 lb injectors.
    Oh no! I've got the horsepower bug now.
    Thank you
    Hobbit
    Dec 2006
    Ontario, Canada
    1,348
    I wouldn't use any type of goo but they do sell gasket material at most part stores so you could cut your own gasket. I would use one of those.
