PDA
View Full Version : {CARB-SWAP}Points ---> Electronic Ignition...Complete!
grandpaslincoln
02-23-2005, 09:38 PM
So I got my electronic ignition conversion kit in the mail today, installed it with no problems.
http://www.grandmarq.net/jonpics/ign/ign001.jpg
It's a Crane Cams XR-1 points conversion kit.
http://www.grandmarq.net/jonpics/ign/ign002.jpg
The unit is pretty small, and it even comes with a built in rev limiter that you can adjust from 4000-8000 RPM.
http://www.grandmarq.net/jonpics/ign/ign003.jpg
A view of the points and condenser that have been giving me so much trouble.
http://www.grandmarq.net/jonpics/ign/ign004.jpg
The entire points system gets replaced, including the plates.
http://www.grandmarq.net/jonpics/ign/ign005.jpg
The new electronic ignition installed in the distributor. The instructions said to remove the distributor, but I really didn't feel like having to pull it and then readjust the timing. It was easy to do it with the distributor on the car.
http://www.grandmarq.net/jonpics/ign/ign006.jpg
Put the cap back on after you have adjusted the electronic shit, and your good to go! The car started right away, and runs so much smoother.
It was simple to install, took about an hour from start to finish.
Lincolnmania
02-23-2005, 09:41 PM
cool man! lookin good
TommyN
02-23-2005, 10:56 PM
Does that Crane kit come with a rev limiter? I seem to recall they do.
Great upgrade.
Tom
phayzer5
02-24-2005, 03:03 AM
What did that kit set ya back?
grandpaslincoln
02-24-2005, 03:36 AM
$64.88 + S&H = 70 somethin
Cogs
02-24-2005, 11:42 AM
Wtf car has points? They still used points in the 80s? I need to do this on my buick, maybe it will get it running. Whered you get the kit from??
Ifixyawata
02-24-2005, 12:35 PM
No, he converted from CFI/Electronic -> Carb/Points -> Carb/Electronic
grandpaslincoln
02-24-2005, 02:24 PM
Ford dropped the points ignition system in 1974 and went electronic.
Cogs, I ordered the kit from summit, but they only have them for the Ford V8 and Chevy V8. I think I may be losing my mind, but Buick is a GM product right? You might want to call them and ask if the Chevy conversion will work with a buick distributor. Worth a try anyway. Its only a two wire hook up, pretty easy.
---EDIT---
Cogs, what year is your buick? Pertronix offers a kit for the buick, but it's only from 1957-74. That particular kit is $74.95
