I need in-depth info on the current Panther driveline.
    I mean everything.
    Engine Block
    Head Type
    Transmission
    Rear Axle
    Brake disc size
    Got a nutty idea and need to know if the 06 and up are the exact same stuff or how far the current dive lines go back.
    Also can one drop the 03-04 Cobra head on the current panther production 4.6 block?
    2008 Mercury Grand Marquis GS Bone Stock
    The modern definition of "racist" is "someone who is arguing with a Liberal".--updated Peter Brimelow quote.
    Anyone?????
      I can't give you any useful info on the specs of the newer cars, but you should be able to put Cobra heads on a new block. The Mustang and Panther use the same block, don't they?
      1998 Crown Victoria P71: Former National Institiute of Health vehicle
      1974 VW Beetle
        The mustangs used the same everything as the Police Interceptors.
          i dont know. would you need a new chain tensioner and timing chain cover?
          im sure the tranny is stil 4R70W or 4R75W
          and gears should be 3.08 or 3.27
          they upgrade in brakes that i know of was in 03+ panthers.
          and i dont think theyve changed the engine much.
          08 Lincoln Navigator L - 233k
          03 Mercury Marauder- 63k
            ok, here goes.
            you can put cobra heads on the new newer block. however the older 4.6's require some modificationings. i'm not exactly sure the extent of the mods, but it can be done (i think it's actually just swapping over the pi intake and timing setup)
            the 4r70w trans a 4r70w is a 4r70w (well, ok, except 4x4 trucks :P)
            rear end is a an 8.8.
            my suggestion, find a wrecked markviii and drop the eng/trans in!
            GMNRadio DJ, Podcast Co-Host
            95 S10 93 Accord
              Is the current block the same as the Mustang GT block?
                IIRC a DOHC won't fit in anything older than an 03. Without a ton more work that is.
                  SO as far as ordering aftermarket parts, the current block and the Mustang GT block are the same, correct?
                    Hello????
                      If you scroll down to the reader comments, it might help XD
                        Thanks...
                          Actually the current transmission is a 4r75w..And yes 2v heads and 4v heads will bolt on a 08-91 block. 3v heads will not work on the old block they have a propriatary block.
                          The current axle is a 8.8 with 31 spline axles
                          R.I.P Linsey Nelson
                          Originally posted by MeanVic84
                          Chocolate Rain. Some stay dry and others feel the pain.
                            Thanks mang! I knew the 3v heads wont work, I was wondering about he older bolt-ons.
                            Thanks for all the info guys!
