PDA
View Full Version : The Brown Blob. 1987 Two Door Crown Victoria
87gtVIC
11-27-2010, 02:37 PM
https://www.youtube.com/watch?v=bHG1cV43wNU
Upgrades/Specs. include:
Engine:
New LMR 5.0 302 V8 (SEFI) with Forged Pistons (LRS-6009EF)
HO Conversion with A9P
Tuned by Willie at Dirty Dog Racing with a Moates Quarterhorse
Mass Air Conversion using 2008 Crown Victoria 80mm Slot Style MAF
Trick Flow 170 Twisted Wedge Cylinder Heads (TFS-51410004-M61) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=764698&viewfull=1#post764698)
NGK FR5 Spark Plugs gapped at 37
ARP Cylinder Head Bolts (ARP-154-3601)
Trick Flow Push Rods (TFS-21406700)
Trick Flow Stage 1 Camshaft (TFS-51403001)
Trick Flow 1.6 Roller Rockers (TFS-51400510)
Trick Flow Double Roller Timing Chain (TFS-51478520)
Ford Racing Roller Lifters (M-6500-R302)
Ford Racing Harmonic Balancer (FMS-M-6316-M50)
ASP Racing Aluminum Underdrive Crank Pulley (ASP928900) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=803902&viewfull=1#post803902)
24LB Denso Blue Top Fuel Injectors
TMoss Ported GT 40 Lower Intake (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=807809&viewfull=1#post807809)
Lightning GT 40 Tubular Intake
Custom Powder Coated GT 40 "Ford Racing" Tubular Intake Plaque (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=849011&viewfull=1#post849011)
Lightning EGR Spacer
Lightning 65mm Throttle Body
Trick Flow 3/8” Phenolic Intake Spacer (TFS-51520017)
Trick Flow Valve Covers (TFS-51411801)
Trick Flow Oil Fill Neck (TFS-51400800)
SVE High Torque Mini Starter (LRS-11002B)
ICT Billet EGR Delete Plate (551604)
TAB, TAD, EGR and Smog Delete
McCully racing Motors TFI (Thick Film Ignition) Relocation Kit (Mounted on Core Support) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=706832&viewfull=1#post706832)
ARP Oil Pump Drive Shaft (154-7904)
NOS Ford Metal/Rubber Valve Cover Gaskets (http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/DSC03412.jpg)
1990 Ford LTD Crown Victoria Drivers Side Inner Fender with Plastic Vacuum Reservoir/Relay Combo (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=462936&viewfull=1#post462936)
2006 Ford Crown Victoria Police Interceptor Air Intake Box (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=464190&viewfull=1#post464190)
2006 Ford Crown Victoria Police Interceptor Zip Tube
K&N High Performance Air Filter (33-2272) (http://i715.photobucket.com/albums/ww156/87gtVIC/My%20Car/DSC02963.jpg)
Ford Racing 9mm High Performance Spark Plug Wire Set (M-12259-M301) (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04718.jpg)
Spark Plug Wire Separators (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=659486&viewfull=1#post659486)
MSD V8 Cap and Rotor Kit (8482) (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04719.jpg)
New Motorcraft IAC and Coil (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=845152&viewfull=1#post845152)
Billet Specialties Ball Milled Wire Loom Holder (69520) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=658154&viewfull=1#post658154)
New Duralast Engine Coolant Temperature Sensor (SU201)
New Motorcraft Fuel Filter
New Duralast Alternator Belt (505K6)
New REM Reproduction UnderHood Hood Liner (FM-753) (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04940.jpg)
New DEA Engine Mounts (A2437, A2438)
Walbro 190 lph Fuel Pump
1985 Ford LTD Crown Victoria 351 Oil Cooler Set up with replacement Derale 15405 Cooler (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=832846&viewfull=1#post832846)
Moroso Oil Seperator Kit for PCV System (85481)
Moroso Oil Seperator Kit for Valve Cover Breather Tube (85632)
Transmission:
Tremec Heavy Duty World Class T5 (M7003ZB)
Tremec T-5 Bellhousing (M6392E)
Ford Performance Heavy Duty 10.5 Clutch Kit (M7560A302)
Ford Performance Billit Steel Flywheel (M6375C302B)
Ford Performance Pilot Bushing (LRS-7600A)
Clutch Fork Dust cover (LRS-7513AK)
Ford Performance Hurst Billet Plus Shifter (M7210M)
Hurst Chrome Stick (0090)
SpeedDawg Hurst Racing Stripe Shift Knob (H502HU-MBK-5RDR)
Hurst Super Boot Shifter Boot (114-7494) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=850467&viewfull=1#post850467)
Royal Purple Syncomesh Fluid (RP-SCM)
Double Hook Clutch Quadrant (LRS-7553C)
Maximum MotorSports Clutch Cable (MMCL-11)
Maximum MotorSports Firewall Adjuster (MMCL-3)
Maximum MotorSports Clutch Cable Heat Shield (MMCL-15)
Custom Pedal Assembly with 1972 Mustang clutch and brake pedals (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=810949&viewfull=1#post810949)
1995 Ford Crown Victoria CVPI Aluminum Drive Shaft (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=705696&viewfull=1#post705696)
Spicer Greasable 5-134x combination U Joints
Exhaust:
Dual Exhaust
New Bosch Premium Oxygen Sensors (13593) (http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/DSC03220.jpg)
Ford Racing Ceramic Coated Headers (M-9430-P51)
BBK CNC Series Off-Road Race H-Pipes (1507) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=775559&viewfull=1#post775559)
Two Walker 2 1/4” Intermediate Pipes ( 43281) (http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/DSC03307.jpg)
Two Walker 2-1/4” ID to 2-1/2” OD Exhaust Adapters (41963)
Two Polished Stainless Steel MAGNAFLOW Performance Flow Through 2.5” In/Out Offset/Offset Mufflers (11236) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=583415&viewfull=1#post583415)
Walker Impala Tailpipes (45016, 45017)
24" 2.5 tail pipe extensions (17635)
Easy Seal Exhaust Clamps from Tailpipe to Tailpipe Extension (ES 250-SS)
3A Racing 2 1/2" Turn Downs ( 17605)
Suspension:
Genuine 1998 Ford Crown Victoria HPP Lacy Wheels with polished Lips and Black Centers (New Yokohama Avid Envigor High Performance All Seasons 235/60/16)
New 2001 Ford Crown Victoria Sport Replica Wheels (New General Grabber UHP 255/50/17) (ALY03471U20N) (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC05546_zps9317f53a.jpg)
98-02 NON ABS Master Cylinder and Booster (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=771344&viewfull=1#post771344)
Big Brake Conversion (Everything New) (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC05534_zpse2cbef92.jpg)
Rear Disc Conversion (Everything New) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=710846&viewfull=1#post710846)
NOS Ford Rear Disc Brake Dust/Splash Shields (F5AZ 2C028A) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=804947&viewfull=1#post804947)
Re manufactured Motorcraft 99 to 02 Police Interceptor Steering Box (XW7Z-3504-ABRM,STG-35-RM) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=729976&viewfull=1#post729976)
Ford Racing 3.73 Ring and Pinion (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=709412&viewfull=1#post709412)
Ford Racing Axle Girdle (M-4033-G2) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=826944&viewfull=1#post826944)
CNC machined 6061 T6 Billet Aluminum1.25" Hubcentric Wheel Spacers in Rear (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC05645_zps221f21be.jpg)
Energy Suspension Body Bushings (9.4102R) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=665415&viewfull=1#post665415)
Energy Suspension Front Control Arm Bushings (4.3150R) (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04617.jpg)
Energy Suspension Lower Control Arm Bump Stops (9-9150R)
Energy Suspension Rear Control Arm Bushings (4.3151R)
ADTR 79-97 Panther Adjustable Rear Trailing Arms (ADTR_7997_CA) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=852975&viewfull=1#post852975)
Energy Suspension Transmission Mount (4.1104G) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=666490&viewfull=1#post666490)
Energy Suspension Shock Bushings Front and Rear (9-8104R)
Speedway Motors Tru-Coil 925# Front 1” Lowering Springs (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=587970&viewfull=1#post587970)
Speedway Motors Tru-Coil 225# Rear 1” Lowering Springs (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=586654&viewfull=1#post586654)
Moog Rear Coil Spring Insulator (K62032)
KYB Gas Adjusts Shock Front ( KG5458) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=789357&viewfull=1#post789357)
KYB Gas Adjusts Shocks Rear (KG5521)
1987 Ford LTD Crown Victoria P72 Police 1” Rear Anti-Sway Bar
1998 1 1/8" Crown Victoria Front Sway Bar (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=780673&viewfull=1#post780673)
Moog Stabilizer Bar End Links (K8953) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=780673&viewfull=1#post780673)
Energy Suspension Sway Bar Bushings (9.5170R) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=780673&viewfull=1#post780673)
Curt V-5 2" Receiver Trailer Hitch (S-048) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=687298&viewfull=1#post687298)
1989 Mercury Colony Park Power Steering Cooler (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=575987&viewfull=1#post575987)
1986 Ford Country Squire Fender Braces (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04625.jpg)
1987 Lincoln Town Car Chassis Braces (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=561241&viewfull=1#post561241)
All New Brake Lines
Hurst Line Loc (1745000K) (http://www.grandmarq.net/vb/attachment.php?attachmentid=51660&d=1550944529)
Heating and Cooling:
Automatic Climate Control
Complete R134 AC Conversion (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=831920&viewfull=1#post831920)
NOS Ford Heater Core (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=524825&viewfull=1#post524825)
New Dayco Heater Hoses (http://i715.photobucket.com/albums/ww156/87gtVIC/My%20Car/DSC02901.jpg)
1986 Ford Crown Victoria Specific Heater Pipe (Concealed Underneath Plenum) (http://i715.photobucket.com/albums/ww156/87gtVIC/My%20Car/DSC03011.jpg)
NOS Ford Heater Core Flow Restrictor
Motorcraft Fan Clutch (YB-327)
1990 Lincoln Town Car Fan Shroud/Coolant Reservoir (http://i715.photobucket.com/albums/ww156/87gtVIC/My%20Car/DSC01963.jpg)
New SPECTRA PREMIUM 3 Core Radiator (CU552)
Ford Racing 16lb Radiator Cap (M8100A)
New Dayco Upper Radiator Hose
New Dayco Lower Radiator Hose
1989 Mercury Colony Park Radiator Air Damn/Deflector (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=563428&viewfull=1#post563428)
1979 Ford LTD Landau Bumper Mounted Air Deflector (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=660837&viewfull=1#post660837)
1993 Mercury Grand Marquis Belly Pan (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC05587_zpsd1780ce4.jpg)
Lighting:
Hella H4 Low Beams (HLA-008888101) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=633681&viewfull=1#post633681)
Hella H1 High Beams (HLA-003177871) (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04519.jpg)
NOS 4 Piece Set of 1979 Clear Lenses (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04469.jpg)
New Long Life Sylvania 1157 A Amber Bulbs (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04469.jpg)
New Long Life Sylvania 194 NA Amber Bulbs (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04469.jpg)
Automatic Headlamps with Delay
Relayed Headlights (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=484672&viewfull=1#post484672)
Ceramic H4 Headlight Connectors (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=724089&viewfull=1#post724089) (http://www.cycleterminal.com/headlight-connectors.html)
New Wells Autolamp Headlight Switch
1989 Lincoln Town Car Under Seat Courtesy Lights (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=687370&viewfull=1#post687370)
1985 Ford F250 Retractable Underhood Light (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=623730&viewfull=1#post623730)
1991 Ford Escort GT Fog Lamps Behind Grille (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04531.jpg)
Relayed Fog Lamps (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=780241&viewfull=1#post780241)
Pilot Xenon Super White Fog Light Bulbs (881)
D&J Streetrod Accessories 5/32" Yellow Low Fuel Indicator Installed in Speedometer (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC05363_zpsb5143e52.jpg)
Paneltronics 5/16 Red Indicator Lights for Fog Lamp and Amp Pull Switch (PANL001308) (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04666.jpg)
Daniel Stern Marker Flasher Mod (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=486776&viewfull=1#post486776)
Lightlens.com 5 Way Green L.E.D.s Installed in Gauge Cluster (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=524200&viewfull=1#post524200)
Pilot Green Gel Cap Covers in All Gauges (WI-801G) (http://i715.photobucket.com/albums/ww156/87gtVIC/My%20Car/DSC03062.jpg)
Instrumentation:
AutoMeter NV Series Digital Gauges (7378) Installed inside Custom Molded Sunpro A Pillar Gauge Pod
1987 Ford Crown Victoria Certified Calibration 140MPH Police Speedometer (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04950.jpg)
Autometer Arctic White Electrical Water Temp. Gauge Installed in Above (1337)
Autometer Arctic White Electrical Oil Pressure Gauge Installed in Above (1327) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=796813&viewfull=1#post796813)
1987 Ford Crown Victoria Police Auxiliary Gauge Bezel (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04952.jpg)
Autometer Arctic White Voltmeter Gauge Installed in Above (1391)
Autometer Arctic White Vacuum/Boost Gauge Installed in Above (1372)
Autometer Arctic White Tacometer Gauge Installed in Above (1397) (http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/IMG_5645.jpg)
Raptor Performance Single Mode Shift Light in Green
Raptor Performance Line Lock Indicator Light in Red
1965 Mustang Seatbelt Reminder (C6OZ-10C876-A1) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=848817&viewfull=1#post848817)
1965 Mustang Parking Brake Warning Light (C4DZ-15A852-A1) (http://www.grandmarq.net/vb/attachment.php?attachmentid=55259&d=1605896715)
Electrical:
New (NOT REMANUFACTURED)130 amp High Output Duralast Gold Alternator (DLG7734-6-11) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=517691&viewfull=1#post517691)
Littlefuse Mega Fuse Holder
New Duralast Gold 1000 Cranking Amp Battery (65-DLG) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=478802&viewfull=1#post478802)
VTE Warehouse Positive Battery Terminal Insulator (416) (http://i715.photobucket.com/albums/ww156/87gtVIC/My%20Car/DSC03119.jpg)
VTE Warehouse Starter Cable Terminal Insulator on Fender Mounted Solenoid (216) (http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/DSC03839.jpg)
VTE Warehouse HOT IN RUN Terminal Insulator on Fender Mounted Solenoid (218) (http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/DSC03839.jpg)
VTE Warehouse Ignition Signal Terminal Insulator on Fender Mounted Solenoid (212) (http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/DSC03840.jpg)
Heavy 000 (3/0) Positive Battery Cable (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=481440&viewfull=1#post481440)
Heavy 4-gauge Negative Battery Cable (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=481440&viewfull=1#post481440)
New (NOT REMANUFACTURED)Window Motors (LRS-23394K) (http://i715.photobucket.com/albums/ww156/87gtVIC/My%20Car/DSC02613.jpg)
Tripminder
Cruise Control
Theft Deterrent Alarm System
Valiant Keyless Entry and Trunk Pop (2RTA)
One-Touch Up/Down Drivers and Passengers Side Windows (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=560735&viewfull=1#post560735)
6 Way Power Driver and Passenger Seat (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=462186&viewfull=1#post462186)
1990 Lincoln Town Car Automatic Trunk Closer (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=503989&viewfull=1#post503989)
1991 Lincoln Mark VII Automatic Trunk Closer Cover (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=560363&viewfull=1#post560363)
1984 Ford Crown Victoria Fuel Door Popper
1993 Mercury Grand Marquis Underhood Fuse Box (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=505614&viewfull=1#post505614)
NOS Ford Power Mirrors (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=552182&viewfull=1#post552182)
NOS Fuel Level Sender (E0ly9275B) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=644164&viewfull=1#post644164)
1996 Chevrolet Lumina Rear View Mirror Equipped with Courtesy Lighting/Reading Lamps (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=462540&viewfull=1#post462540)
1983 Ford Country Squire Amplifier Pull Switch for Amplifier (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC05292_zpsd7ce4c27.jpg)
1985 Ford Mustang Fog Lamp Switch (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=655423&viewfull=1#post655423)
Ignited Performance Products 2005 Series L.E.D Racing Protector Cover Cut-Off Switch
New Duralast Passengers Side Door Jamb Courtesy Light Switch (SW99)
NOS Ford Power Antenna Motor
1993 Ford Crown Victoria Washer Fluid Reservoir (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=463327&viewfull=1#post463327)
Tridon EL-12 Electronic Turn Signal Flasher
1985 Ford Mustang Dual Warning Buzzer
Relayed Blower Motor (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=710941&viewfull=1#post710941)
Tekonsha 119147 trailer light power module and a Tow-Ready 118149 4-Flat Universal Mounting Bracket (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=828036&viewfull=1#post828036)
Paint:
Fresh Paint (Hot Chocolate Metallic) (A88 BMW Color) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=579318&viewfull=1#post579318)
Matrix Base Coat (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=585189&viewfull=1#post585189)
Virtus High Solids Clearcoat
High Build Two Stage 2K Epoxy Primer
1979 Ford LTD Bumper Insert Treatment (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=753945&viewfull=1#post753945)
VHT NiteShaded and Clearcoated Ditch Lights and Rear Parking Lights (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=689963&viewfull=1#post689963)
A HUGE List of Other Things are Painted on this Vehicle
Exterior:
Brand New Vinyl Top (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=535334&viewfull=1#post535334)
ProStripe Bright Gold Pinstripping (R320106) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=758175&viewfull=1#post758175)
Scott Drake 68-69 Torino Ford Letters on Trunk Lid (67HD) (http://www.grandmarq.net/vb/attachment.php?attachmentid=54839&d=1599314284)
Hurst Equipped Emblem on Trunk Lid (HUR-136100) (http://www.grandmarq.net/vb/attachment.php?attachmentid=54838&d=1599314284)
Body Side Molding Delete (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=442307&viewfull=1#post442307)
Trunk Molding Delete (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC05651_zps5ac52f83.jpg)
1979 Ford LTD Landau Sill Plate Moldings (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=666233&viewfull=1#post666233)
New 1963 Ford Galaxie LTD Sill Plate Emblems (C5ZZ-6513208-E) (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04900.jpg)
1979 Specific Ford LTD Crown Victoria Chrome Rear License Plate Bucket (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=580540&viewfull=1#post580540)
1981 Ford LTD Crown Victoria Grille (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=442744&viewfull=1#post442744)
The Hillman Group Stainless Steel Black Headed Grille Screws
Mcgard Chrome Lugs with Two Locking Lugs Per Wheel (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=398441&viewfull=1#post398441)
Tinted Windows (20%)
1982 Ford LTD Crown Victoria Tail Lights (http://i715.photobucket.com/albums/ww156/87gtVIC/My%20Car/DSC02551.jpg)
Blacked out Ditch Light Bezels (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=456207&viewfull=1#post456207)
Blacked Out Headlight Bezels (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=463869&viewfull=1#post463869)
Spartan Heavy-Duty Vinyl Body Shield Accent Stripes on Lower Body Moldings (T9021) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=456207&viewfull=1#post456207)
New Rear Window Trim Retainer Clips (LRS-42413B)
1989 Ford Crown Victoria Stainless Steel Rear Window Trim (http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/DSC03709.jpg)
1989 Mercury Grand Marquis Stainless Steel Rocker Panel Moldings
NOS Ford Hood Ornament (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=515109&viewfull=1#post515109)
NOS B Pillar Crown Trim Emblems (E0AB-5450398-AA) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=739364&viewfull=1#post739364)
New Door Handles (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=554302&viewfull=1#post554302)
New Auto Ventshades Stainless Steel Rain Guards (F-85) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=461920&viewfull=1#post461920)
Highland The Pro's Brand Stainless Steel/Rubber Mudflaps (http://i715.photobucket.com/albums/ww156/87gtVIC/My%20Car/DSC02721.jpg)
New Door Strikers (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=491897&viewfull=1#post491897)
CST Locking Fuel Cap
WeatherShield HP Custom Fit Tue-Toned Car Cover (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=677943&viewfull=1#post677943)
Interior:
VERY Good Condition Interior Very Presentable
Dead Silent Interior
Beige Interior
Re-padded Front Seats
Auto-Expressions Beige Seat Covers on Front 50/50 Split Bench Seats to cover cracked pleather
Auto-Expressions Beige Seat Cover on Rear Seat to match front seats
NOS Ford "Casseter" mounted under drivers side seat (E5AZ 19A089 A) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=850777&viewfull=1#post850777)
Newark Auto Synthetic Fiber 1/2” Thick Carpet Underpadding (1753) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=525044&viewfull=1#post525044)
Quick Roof Sound Deadened Interior (http://i715.photobucket.com/albums/ww156/87gtVIC/My%20Car/DSC02149.jpg)
Custom Embroidered “LTD” Armrests (http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/DSC03848.jpg)
Custom Door Panel Vapor Barriers
Custom Fire Extinguisher Mount Behind Drivers Seat (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=714163&viewfull=1#post714163)
1985 Ford Mustang GT Dead Pedal (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC05292_zpsd7ce4c27.jpg)
1984 Mercury Grand Marquis Under-Dash Carpeting (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=463327&viewfull=1#post463327)
Lighted Vanity Mirrors
New Door Panel Pull Handles (291-1350CC) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=504567&viewfull=1#post504567)
Wheelskins leather wrapped Steering wheel. Sand in color, with baseball stitch. (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=627168&viewfull=1#post627168)
Custom 1984 Mustang Halo Headrests With Matching Auto-Expressions Covers (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=581501&viewfull=1#post581501)
Coverking Dash Pad to cover cracked dash pad
Coverking Deck Lid to match front Carpeted Dash
1992 Lincoln Town Car Rear Deck Speaker Covers (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=475056&viewfull=1#post475056)
1978 Lincoln Mark V Chrome Accelerator Pedal Cover (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC05292_zpsd7ce4c27.jpg)
1972 Lincoln Continental Chrome Emergency Brake Pedal Cover (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04280.jpg)
1987 Mercury Cougar Beige Seat Back Mounted Seat Belt Guides (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=623896&viewfull=1#post623896)
1979 Ford LTD Landau Side Seat Trims (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=666548&viewfull=1#post666548)
Ford OEM Accessories Floor Mats (XW7Z-5413300-CAA) (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=726985&viewfull=1#post726985)
Tan Center Console (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=659651&viewfull=1#post659651)
Custom 1986 Mercury Grand Marquis Horn Pad (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=527987&viewfull=1#post527987)
1981 Ford Thunderbird Black Lower Steering Column Bezel (http://i715.photobucket.com/albums/ww156/87gtVIC/My%20Car/DSC01889.jpg)
1986 Mustang Upper Tilt Steering Column Cover
1990 Mercury Cougar Black Dome Light (http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/DSC03495.jpg)
1979 Ford Bronco Clear Dome Light Lens (47-4291)
NOS Ford Window Guide Rod Bushings (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=487243&viewfull=1#post487243)
NOS 1979 Ford LTD Crown Victoria Tilt Column Lever (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04376.jpg)
NOS 1985 Ford Crown Victoria Directional Lever (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04373.jpg)
NOS 1987 Ford Crown Victoria Interval Wiper Switch (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC04375.jpg)
Retro 80's Steering Column Lock Powder Coated Black (http://i1143.photobucket.com/albums/n636/david87gtVIC/DSC05864_zpsc5f15661.jpg)
NOS Glove Box Latch
NOS Ford Key Cylinder to Ignition Switch Actuator
1985 Ford Crown Victoria Trunk Hinge Bumpers
1987 Mercury Grand Marquis Under Armrest Panels with Courtesy Lights (http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/IMG_5054.jpg)
Sound System:
1986 Lincoln Town Car Premium Sound Head Unit (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=848409&viewfull=1#post848409)
AudioControl LCQ-1 Line Out Converter (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=848409&viewfull=1#post848409)
Jensen Power Plus 1300W 4 Channel Amplifier (http://i715.photobucket.com/albums/ww156/87gtVIC/My%20Car/DSC02547.jpg)
10” Infinity BassLink Powered Subwoofer (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=780898&viewfull=1#post780898)
Rockford Fosgate Power Distribution Block(RFD1)
Sony Xplod 4” Two Way Speaker in Dash
Jensen 6.5” Triaxial Speaker with Swivel Tweeters Mounted in Doors
Jensen 6”x9” Triaxial Speaker with Swivel Tweeters Mounted in Rear Deck
Metra Electronics RCA Gold Connector Cables (AW-RCA20)
Jasco 14 Gauge Copper and Silver Speaker Wiring
4 Gauge Power/Ground Wires for Amplifier
Weatherstripping:
New Metro Molded Parts INC. Passengers and Drivers Side Window Channel Weatherstripping (WC 33-96)
New FairChild Industries Dew Wipes (http://www.grandmarq.net/vb/showthread.php?29894-The-Official-Dew-Wipe-Replacement-Thread&highlight=dew+wipes)
New Precision Replacement Parts Body to Door Seals (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=472370&viewfull=1#post472370)
New FairChild Industries Trunk Weatherstripping (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=491897&viewfull=1#post491897)
New Cowl to Hood Seal (http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB&p=495576&viewfull=1#post495576)
Build thread:http://www.grandmarq.net/vb/showthread.php?26257-My-1987-Two-Door-Crown-Victoria-AKA-THE-BROWN-BLOB
