Upgrades/Specs. include:
Engine:
- New LMR 5.0 302 V8 (SEFI) with Forged Pistons (LRS-6009EF)
- HO Conversion with A9P
- Tuned by Willie at Dirty Dog Racing with a Moates Quarterhorse
- Mass Air Conversion using 2008 Crown Victoria 80mm Slot Style MAF
- Trick Flow 170 Twisted Wedge Cylinder Heads (TFS-51410004-M61)
- NGK FR5 Spark Plugs gapped at 37
- ARP Cylinder Head Bolts (ARP-154-3601)
- Trick Flow Push Rods (TFS-21406700)
- Trick Flow Stage 1 Camshaft (TFS-51403001)
- Trick Flow 1.6 Roller Rockers (TFS-51400510)
- Trick Flow Double Roller Timing Chain (TFS-51478520)
- Ford Racing Roller Lifters (M-6500-R302)
- Ford Racing Harmonic Balancer (FMS-M-6316-M50)
- ASP Racing Aluminum Underdrive Crank Pulley (ASP928900)
- 24LB Denso Blue Top Fuel Injectors
- TMoss Ported GT 40 Lower Intake
- Lightning GT 40 Tubular Intake
- Custom Powder Coated GT 40 "Ford Racing" Tubular Intake Plaque
- Lightning EGR Spacer
- Lightning 65mm Throttle Body
- Trick Flow 3/8” Phenolic Intake Spacer (TFS-51520017)
- Trick Flow Valve Covers (TFS-51411801)
- Trick Flow Oil Fill Neck (TFS-51400800)
- SVE High Torque Mini Starter (LRS-11002B)
- ICT Billet EGR Delete Plate (551604)
- TAB, TAD, EGR and Smog Delete
- McCully racing Motors TFI (Thick Film Ignition) Relocation Kit (Mounted on Core Support)
- ARP Oil Pump Drive Shaft (154-7904)
- NOS Ford Metal/Rubber Valve Cover Gaskets
- 1990 Ford LTD Crown Victoria Drivers Side Inner Fender with Plastic Vacuum Reservoir/Relay Combo
- 2006 Ford Crown Victoria Police Interceptor Air Intake Box
- 2006 Ford Crown Victoria Police Interceptor Zip Tube
- K&N High Performance Air Filter (33-2272)
- Ford Racing 9mm High Performance Spark Plug Wire Set (M-12259-M301)
- Spark Plug Wire Separators
- MSD V8 Cap and Rotor Kit (8482)
- New Motorcraft IAC and Coil
- Billet Specialties Ball Milled Wire Loom Holder (69520)
- New Duralast Engine Coolant Temperature Sensor (SU201)
- New Motorcraft Fuel Filter
- New Duralast Alternator Belt (505K6)
- New REM Reproduction UnderHood Hood Liner (FM-753)
- New DEA Engine Mounts (A2437, A2438)
- Walbro 190 lph Fuel Pump
- 1985 Ford LTD Crown Victoria 351 Oil Cooler Set up with replacement Derale 15405 Cooler
- Moroso Oil Seperator Kit for PCV System (85481)
- Moroso Oil Seperator Kit for Valve Cover Breather Tube (85632)
Transmission:
- Tremec Heavy Duty World Class T5 (M7003ZB)
- Tremec T-5 Bellhousing (M6392E)
- Ford Performance Heavy Duty 10.5 Clutch Kit (M7560A302)
- Ford Performance Billit Steel Flywheel (M6375C302B)
- Ford Performance Pilot Bushing (LRS-7600A)
- Clutch Fork Dust cover (LRS-7513AK)
- Ford Performance Hurst Billet Plus Shifter (M7210M)
- Hurst Chrome Stick (0090)
- SpeedDawg Hurst Racing Stripe Shift Knob (H502HU-MBK-5RDR)
- Hurst Super Boot Shifter Boot (114-7494)
- Royal Purple Syncomesh Fluid (RP-SCM)
- Double Hook Clutch Quadrant (LRS-7553C)
- Maximum MotorSports Clutch Cable (MMCL-11)
- Maximum MotorSports Firewall Adjuster (MMCL-3)
- Maximum MotorSports Clutch Cable Heat Shield (MMCL-15)
- Custom Pedal Assembly with 1972 Mustang clutch and brake pedals
- 1995 Ford Crown Victoria CVPI Aluminum Drive Shaft
- Spicer Greasable 5-134x combination U Joints
Exhaust:
- Dual Exhaust
- New Bosch Premium Oxygen Sensors (13593)
- Ford Racing Ceramic Coated Headers (M-9430-P51)
- BBK CNC Series Off-Road Race H-Pipes (1507)
- Two Walker 2 1/4” Intermediate Pipes ( 43281)
- Two Walker 2-1/4” ID to 2-1/2” OD Exhaust Adapters (41963)
- Two Polished Stainless Steel MAGNAFLOW Performance Flow Through 2.5” In/Out Offset/Offset Mufflers (11236)
- Walker Impala Tailpipes (45016, 45017)
- 24" 2.5 tail pipe extensions (17635)
- Easy Seal Exhaust Clamps from Tailpipe to Tailpipe Extension (ES 250-SS)
- 3A Racing 2 1/2" Turn Downs ( 17605)
Suspension:
- Genuine 1998 Ford Crown Victoria HPP Lacy Wheels with polished Lips and Black Centers (New Yokohama Avid Envigor High Performance All Seasons 235/60/16)
- New 2001 Ford Crown Victoria Sport Replica Wheels (New General Grabber UHP 255/50/17) (ALY03471U20N)
- 98-02 NON ABS Master Cylinder and Booster
- Big Brake Conversion (Everything New)
- Rear Disc Conversion (Everything New)
- Red Powder Coated Calipers
- NOS Ford Rear Disc Brake Dust/Splash Shields (F5AZ 2C028A)
- Re manufactured Motorcraft 99 to 02 Police Interceptor Steering Box (XW7Z-3504-ABRM,STG-35-RM)
- Ford Racing 3.73 Ring and Pinion
- Ford Racing Axle Girdle (M-4033-G2)
- CNC machined 6061 T6 Billet Aluminum1.25" Hubcentric Wheel Spacers in Rear
- Energy Suspension Body Bushings (9.4102R)
- Energy Suspension Front Control Arm Bushings (4.3150R)
- Energy Suspension Lower Control Arm Bump Stops (9-9150R)
- Energy Suspension Rear Control Arm Bushings (4.3151R)
- ADTR 79-97 Panther Adjustable Rear Trailing Arms (ADTR_7997_CA)
- Energy Suspension Transmission Mount (4.1104G)
- Energy Suspension Shock Bushings Front and Rear (9-8104R)
- Speedway Motors Tru-Coil 925# Front 1” Lowering Springs
- Speedway Motors Tru-Coil 225# Rear 1” Lowering Springs
- Moog Rear Coil Spring Insulator (K62032)
- Bilstein #24-014953 Front Shocks
- Bilstein #24-014960 Rear Shocks
- 1987 Ford LTD Crown Victoria P72 Police 1” Rear Anti-Sway Bar
- 1998 1 1/8" Crown Victoria Front Sway Bar
- Moog Stabilizer Bar End Links (K8953)
- Energy Suspension Sway Bar Bushings (9.5170R)
- Curt V-5 2" Receiver Trailer Hitch (S-048)
- 1989 Mercury Colony Park Power Steering Cooler
- 1986 Ford Country Squire Fender Braces
- 1987 Lincoln Town Car Chassis Braces
- All New Brake Lines
- Hurst Line Loc (1745000K)
Heating and Cooling:
- Automatic Climate Control
- Complete R134 AC Conversion
- NOS Ford Heater Core
- New Dayco Heater Hoses
- 1986 Ford Crown Victoria Specific Heater Pipe (Concealed Underneath Plenum)
- NOS Ford Heater Core Flow Restrictor
- Motorcraft Fan Clutch (YB-327)
- 1990 Lincoln Town Car Fan Shroud/Coolant Reservoir
- New SPECTRA PREMIUM 3 Core Radiator (CU552)
- Ford Racing 16lb Radiator Cap (M8100A)
- New Dayco Upper Radiator Hose
- New Dayco Lower Radiator Hose
- 1989 Mercury Colony Park Radiator Air Damn/Deflector
- 1979 Ford LTD Landau Bumper Mounted Air Deflector
- 1993 Mercury Grand Marquis Belly Pan
Lighting:
- Hella H4 Low Beams (HLA-008888101)
- Hella H1 High Beams (HLA-003177871)
- NOS 4 Piece Set of 1979 Clear Lenses
- New Long Life Sylvania 1157 A Amber Bulbs
- New Long Life Sylvania 194 NA Amber Bulbs
- Automatic Headlamps with Delay
- Relayed Headlights
- Ceramic H4 Headlight Connectors (http://www.cycleterminal.com/headlight-connectors.html)
- New Wells Autolamp Headlight Switch
- 1989 Lincoln Town Car Under Seat Courtesy Lights
- 1985 Ford F250 Retractable Underhood Light
- 1991 Ford Escort GT Fog Lamps Behind Grille
- Relayed Fog Lamps
- Pilot Xenon Super White Fog Light Bulbs (881)
- D&J Streetrod Accessories 5/32" Yellow Low Fuel Indicator Installed in Speedometer
- Paneltronics 5/16 Red Indicator Lights for Fog Lamp and Amp Pull Switch (PANL001308)
- Daniel Stern Marker Flasher Mod
- Lightlens.com 5 Way Green L.E.D.s Installed in Gauge Cluster
- Pilot Green Gel Cap Covers in All Gauges (WI-801G)
Instrumentation:
- AutoMeter NV Series Digital Gauges (7378) Installed inside Custom Molded Sunpro A Pillar Gauge Pod
- 1987 Ford Crown Victoria Certified Calibration 140MPH Police Speedometer
- Autometer Arctic White Electrical Water Temp. Gauge Installed in Above (1337)
- Autometer Arctic White Electrical Oil Pressure Gauge Installed in Above (1327)
- 1987 Ford Crown Victoria Police Auxiliary Gauge Bezel
- Autometer Arctic White Voltmeter Gauge Installed in Above (1391)
- Autometer Arctic White Vacuum/Boost Gauge Installed in Above (1372)
- Autometer Arctic White Tacometer Gauge Installed in Above (1397)
- Raptor Performance Single Mode Shift Light in Green
- Raptor Performance Line Lock Indicator Light in Red
- 1965 Mustang Seatbelt Reminder (C6OZ-10C876-A1)
- 1965 Mustang Parking Brake Warning Light (C4DZ-15A852-A1)
Electrical:
- New (NOT REMANUFACTURED)130 amp High Output Duralast Gold Alternator (DLG7734-6-11)
- Littlefuse Mega Fuse Holder
- New Duralast Gold 1000 Cranking Amp Battery (65-DLG)
- VTE Warehouse Positive Battery Terminal Insulator (416)
- VTE Warehouse Starter Cable Terminal Insulator on Fender Mounted Solenoid (216)
- VTE Warehouse HOT IN RUN Terminal Insulator on Fender Mounted Solenoid (218)
- VTE Warehouse Ignition Signal Terminal Insulator on Fender Mounted Solenoid (212)
- Heavy 000 (3/0) Positive Battery Cable
- Heavy 4-gauge Negative Battery Cable
- New (NOT REMANUFACTURED)Window Motors (LRS-23394K)
- Tripminder
- Cruise Control
- Theft Deterrent Alarm System
- Valiant Keyless Entry and Trunk Pop (2RTA)
- One-Touch Up/Down Drivers and Passengers Side Windows
- 6 Way Power Driver and Passenger Seat
- 1990 Lincoln Town Car Automatic Trunk Closer
- 1991 Lincoln Mark VII Automatic Trunk Closer Cover
- 1984 Ford Crown Victoria Fuel Door Popper
- 1993 Mercury Grand Marquis Underhood Fuse Box
- NOS Ford Power Mirrors
- NOS Fuel Level Sender (E0ly9275B)
- 1996 Chevrolet Lumina Rear View Mirror Equipped with Courtesy Lighting/Reading Lamps
- 1983 Ford Country Squire Amplifier Pull Switch for Amplifier
- 1985 Ford Mustang Fog Lamp Switch
- Ignited Performance Products 2005 Series L.E.D Racing Protector Cover Cut-Off Switch
- New Duralast Passengers Side Door Jamb Courtesy Light Switch (SW99)
- NOS Ford Power Antenna Motor
- 1993 Ford Crown Victoria Washer Fluid Reservoir
- Tridon EL-12 Electronic Turn Signal Flasher
- 1985 Ford Mustang Dual Warning Buzzer
- Relayed Blower Motor
- Tekonsha 119147 trailer light power module and a Tow-Ready 118149 4-Flat Universal Mounting Bracket
Paint:
- Fresh Paint (Hot Chocolate Metallic) (A88 BMW Color)
- Matrix Base Coat
- Virtus High Solids Clearcoat
- High Build Two Stage 2K Epoxy Primer
- 1979 Ford LTD Bumper Insert Treatment
- VHT NiteShaded and Clearcoated Ditch Lights and Rear Parking Lights
- A HUGE List of Other Things are Painted on this Vehicle
Exterior:
- Brand New Vinyl Top
- ProStripe Bright Gold Pinstripping (R320106)
- Scott Drake 68-69 Torino Ford Letters on Trunk Lid (67HD)
- Hurst Equipped Emblem on Trunk Lid (HUR-136100)
- Body Side Molding Delete
- Trunk Molding Delete
- 1979 Ford LTD Landau Sill Plate Moldings
- New 1963 Ford Galaxie LTD Sill Plate Emblems (C5ZZ-6513208-E)
- 1979 Specific Ford LTD Crown Victoria Chrome Rear License Plate Bucket
- 1981 Ford LTD Crown Victoria Grille
- The Hillman Group Stainless Steel Black Headed Grille Screws
- Mcgard Chrome Lugs with Two Locking Lugs Per Wheel
- Tinted Windows (20%)
- 1982 Ford LTD Crown Victoria Tail Lights
- Blacked out Ditch Light Bezels
- Blacked Out Headlight Bezels
- Spartan Heavy-Duty Vinyl Body Shield Accent Stripes on Lower Body Moldings (T9021)
- New Rear Window Trim Retainer Clips (LRS-42413B)
- 1989 Ford Crown Victoria Stainless Steel Rear Window Trim
- 1989 Mercury Grand Marquis Stainless Steel Rocker Panel Moldings
- NOS Ford Hood Ornament
- NOS B Pillar Crown Trim Emblems (E0AB-5450398-AA)
- New Door Handles
- New Auto Ventshades Stainless Steel Rain Guards (F-85)
- Highland The Pro's Brand Stainless Steel/Rubber Mudflaps
- New Door Strikers
- WeatherShield HP Custom Fit Tue-Toned Car Cover
- NOS Door Edge Guards
Interior:
- VERY Good Condition Interior Very Presentable
- Dead Silent Interior
- Beige Interior
- 1989 Ford Crown Victoria Cloth Seats
- 1993 Town Car Cup Holder Armrests
- 1993 Town Car Cell Phone Mount
- NOS Ford "Casseter" mounted under drivers side seat (E5AZ 19A089 A)
- Newark Auto Synthetic Fiber 1/2” Thick Carpet Underpadding (1753)
- Quick Roof Sound Deadened Interior
- Custom Door Panel Vapor Barriers
- Custom Fire Extinguisher Mount Behind Drivers Seat
- 1985 Ford Mustang GT Dead Pedal
- 1984 Mercury Grand Marquis Under-Dash Carpeting
- Lighted Vanity Mirrors
- New Door Panel Pull Handles (291-1350CC)
- Wheelskins leather wrapped Steering wheel. Sand in color, with baseball stitch.
- Coverlay Light Brown Dash Cap (Coverlay 12305)
- Coverking Carpeted Deck Lid
- 1992 Lincoln Town Car Rear Deck Speaker Covers
- 1978 Lincoln Mark V Chrome Accelerator Pedal Cover
- 1972 Lincoln Continental Chrome Emergency Brake Pedal Cover
- 1979 Ford LTD Landau Side Seat Trims
- Ford OEM Accessories Floor Mats (XW7Z-5413300-CAA)
- Custom 1986 Mercury Grand Marquis Horn Pad
- 1981 Ford Thunderbird Black Lower Steering Column Bezel
- 1986 Mustang Upper Tilt Steering Column Cover
- 1990 Mercury Cougar Black Dome Light
- 1979 Ford Bronco Clear Dome Light Lens (47-4291)
- NOS Ford Window Guide Rod Bushings
- NOS 1979 Ford LTD Crown Victoria Tilt Column Lever
- NOS 1985 Ford Crown Victoria Directional Lever
- NOS 1987 Ford Crown Victoria Interval Wiper Switch
- Retro 80's Steering Column Lock Powder Coated Black
- NOS Glove Box Latch
- NOS Ford Key Cylinder to Ignition Switch Actuator
- 1985 Ford Crown Victoria Trunk Hinge Bumpers
- 1987 Mercury Grand Marquis Under Armrest Panels with Courtesy Lights
Sound System:
- 1986 Lincoln Town Car Premium Sound Head Unit
- AudioControl LCQ-1 Line Out Converter
- Jensen Power Plus 1300W 4 Channel Amplifier
- 10” Infinity BassLink Powered Subwoofer
- Rockford Fosgate Power Distribution Block(RFD1)
- Sony Xplod 4” Two Way Speaker in Dash
- Jensen 6.5” Triaxial Speaker with Swivel Tweeters Mounted in Doors
- Jensen 6”x9” Triaxial Speaker with Swivel Tweeters Mounted in Rear Deck
- Metra Electronics RCA Gold Connector Cables (AW-RCA20)
- Jasco 14 Gauge Copper and Silver Speaker Wiring
- 4 Gauge Power/Ground Wires for Amplifier
Weatherstripping:
- New Metro Molded Parts INC. Passengers and Drivers Side Window Channel Weatherstripping (WC 33-96)
- New FairChild Industries Dew Wipes
- New Precision Replacement Parts Body to Door Seals
- New FairChild Industries Trunk Weatherstripping
- New Cowl to Hood Seal
Build thread:http://www.grandmarq.net/vb/showthre...THE-BROWN-BLOB
