Greetings!
    Greetings!
    Hello all!
    Brand new here! Thank you for having this site!
    I have an '87 Grand Marquis, technically owned by the family trust, but its mine to maintain...
    Also an '85 Crown Vic, which is the one I need help with... It's been sitting for a while and I'm trying to get it going, smog it (Yeah, California), and sell it. It has that lovely CFI system... Fuel has been changed out, fuel filter has been changed out.
    Trying to start it, it'll start but dies immediately. The only way to keep it running is to keep feathering the gas. As near as I can tell, the only time it actually puts fuel through the injectors is when the gas pedal is moving down. Not holding it down, but actually moving down. Hence the feathering thing...
    I suspect the Engine Control Module is bad, but don't want to drop $100 to test that.
    Anybody seen something like this?
    Thanks again!
    Russ
    Also, in case it makes a difference, it seems to be a late '84. To replace the cap and rotor the '85 doesn't fit. Have to get the one for an '84.
    Thanks!
      Welcome to the Party!!
      08 Lincoln Navigator L - 233k
      03 Mercury Marauder- 63k
        Welcome! I'm not CFI expert, but there's a few guys on here good with them. Stick around and I'm sure we'll get to the bottom of it.
        Where are you located? you may even be near someone who can help you out in person.
          Welcome.
          You may want to post your question is a separate thread with a title summarizing your question/problem.
          like "Help 84/85 engine starts won't run"
          Good luck,
          Jay
            Welcome to the party!
            '79 Continental Town Car
            '90 Crown Victoria LTD
            '94 Crown Victoria
              Welcome man, I hope you find help with your problems.
                Welcome! I had a problem like this one time and it was the ignition switch (located in the column). Ford recalled a ton of years and models b/c of this issue. Car would start and immediately upon letting up on the key it would go dead. Probably not your issue if the car keeps running while you are feathering the gas. Check the TPS and MAP if the 85 CFI has them.
                  Thank you, thank you, and thank you!
                  The ignition switch is also new, it was giving me the standard trouble so replaced... (Replaced the one in my Grand Marquis, too)
                  I'm in Sacramento, CA.
                  I'll repost in an appropriate area, too.
                    Welcome!
                    Sounds like you have a couple of nice cars there. This place is great for knowledge of these cars and advise. I'm sure you'll find an answer soon!
                      Thanks! Reposted in what I hope is the appropriate area.
                      Looking forward to getting this thing solved...
