Incomplete msg. The MAF is in a separate section away from throttle body, correct? between TB and air cleaner? Mine does not seem to have one.
New Guy. 1991 LTD Crown Victoria
Knucklehead, nice to hear from fellow plumbers. I started in 1988 right after I graduated from high school. I have always liked what I do, we are in the commercial industry. Most of my work is on the Oregon State University campus. Maintenance contracts up to new facilities. We have both wet and dry side mechanical at our shop, I run the wet side. I'm very sorry to see you are stuck in the hell that is California. I was down there for a few weeks last spring when grandmothers health was failing. She lived in Modesto, I could not believe the insanity that was going on down there. It was during all that nonsense at Berkeley. I say run, run far far away. If you are ever looking to relocate, get an Oregon license and come see me.1991 lx. Grandmas car. 80k. Garage queen
Very nice!
I believe the MAF would be closer to the air cleaner. Also for a MAF car the air cleaner is mounted in front of the driver side wheel/behind the driver side headlights and header panel while non MAF cars have the air cleaner mounted between the driver side wheel and driver side of the engine (mounted bracket bolted on with studs on the hears of 3 of the exhaust manifold bolts).
Pic of factory SD setup:
The pic below is my engine bay (1991 MGM, SD car) with 1990 Lincoln Town Car air cleaner, fan shroud/coolant overflow, washer bottle setup.
Although this is an SD car, this setup is basically what the MAF setup will look like only with MAF just after the air cleaner.
Vic
Originally posted by sly View Post96 to 97.5 should have the GT40 (non p) heads with the better to work on spark plug angle. The IAT sensor hole was not used on any of them (that I know of), thought the flat spot is there on the earlier intakes.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Originally posted by Rodentkiller View PostHRG the reason I said get a P72 engine and drivetrain is more durable and then you can beef up the engine for some speed, cops tend to abuse their patrol cars so they have to be built tough. So west the fellas have gave you some food for thought.
The other thing to consider is, as you said, those drivetrains tend to be rode hard and put away wet, and even if the mileage on the odometer is low unless it was a detective's car chances are there are a ton of run hours from just idling while out on patrol. That pretty much would mean a full rebuild, including engine block machining, which jacks the overall cost way up. On the other hand low-mileage Explorer engines can still be found, the savings if one doesn't have to touch the bottom end are huge. Take a look at this little gem I'm putting together, she's got around 50k on her and the cylinder walls were flawless, I mean they looked like the block just came from the machine shop! She also runs 55psi of oil pressure with the hand-held cordless drill spinning the oil pump on low speed. I'd say that's a pretty good foundation for a decent performance buildThe ones who accomplish true greatness, are the foolish who keep pressing onward.
there is truly nothing remarkable about the optional 351 engine except how amazingly mediocre it is. And the AC bracket, thats useful if you want to put a 351 based engine in.
The trans and PS coolers are the same as the tow package, not all that large and you can do better with stuff robbed from a 1/2 ton pickup. The oil cooler is nice, but could also be found on the 302.86 Lincoln Town Car (Galactica).
Only thing decent on a p72 is the sway bars and frame. 351 is a boat anchor, same crap tier AOD, most still had open diffs with nothing special in the gear department. Suspension wise everything will be wasted by this point anyways so that's all irrelevant.
Would much rather have a cream puff SEFI civilian car.Last edited by pantera77; 12-16-2017, 02:58 PM.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
I'm thinking Rodenkiller was thinking of it in GM terms, when IIRC the only way to get the LT1 in a Caprice was if it's a police-spec car. Ford didn't do that.The ones who accomplish true greatness, are the foolish who keep pressing onward.
I did find a complete and relatively clean P72 car at Scottfest this year. The sway bars went to Ohio, the AC brackets are on my shelf.86 Lincoln Town Car (Galactica).
That red thing? That was a fire chief's car IIRC, hence why it wasn't all beat to hell and back.The ones who accomplish true greatness, are the foolish who keep pressing onward.
yeah, that one. Dunno, I was just happy to score a set of brackets. No clue if I will ever use them but I now have the option.86 Lincoln Town Car (Galactica).
Yep, started in '99 right out of high school so different generation, but i learned from the old-school. Always worked for a small company until a few years ago. I'm the only person there that's ever leaded a joint. Really depressing. Anyhow, trips me out you got a '91 california car that's SD. Also looks a lot like both my '90s.
And yes, california is a total shithole that's only getting worse by the day. Finally got the wife to agree that this place blows and there's no future here. Now just need to decide where the right place is and get headed that direction. Still gonna take a few years though....ugh.
