live in canada but run over to michigan to ship stuff in the us so it's cheep and quick
-axleshaft for a box, great shape with mint bearing surface $25
-oem converter with 30k miles on it, mint $50
-all oem great shape, good rad, shroud, fan, hoses, byspass valve, mounting hardware $75
-good shape powersteering pump with mint pulley $25
-entire mint cruise control system with cable/vac line with bleed valve, bracket, bolts... $60
-fuel pump hangar assembly with lever sender, new o-ring and lock ring, fairly new walbro 155lph pump $50
-charcoal cannister and evap solenoid $20
-mint intake elbow $5
-mint crank pulley with bolts $15
-relay housing/wiring/assembly $15
-great working stock ecu $40
-2 brand new bosche o2 sensors lengthened to reach o2 sensor locations or stock $30
-2 bosche o2 sensors with like 50 miles on them $20
-mint column shifter $5
-all 3 crash sensors with both plug ends $15
-tab/tad solenoids $10
-brand new temperature switches to turn on electric fans, warning lights... 165* and a 180* switch both the standard 3/8npt $10 each
-1/2npt high flow solenoids with all teflon seals so it can open/close flow to anything and rated to 2000psi, both are brand new and run tripple or more than what i'm asking, $20 each
