Stuff.
Originally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
Nice CV but almost 17K??? Post Pot Law listing.....
That pickup is the bomb. Great stuff.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
that tailgate is almost useless.
Yes it is almost useless but still...03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
I have the Autozone version of that jack set. the jack can't get the tire off the ground using the frame. You have to get it under the car on the lower control arm or the shock mount on the rear axle to get the tires off the ground. This requires added strength for the under the car angle required. To use the jack on the frame requires an added 2x4 spacer.
Originally posted by sly View PostI have the Autozone version of that jack set. the jack can't get the tire off the ground using the frame. You have to get it under the car on the lower control arm or the shock mount on the rear axle to get the tires off the ground. This requires added strength for the under the car angle required. To use the jack on the frame requires an added 2x4 spacer.
I would still buy that set to get the two extra jack stands.
my jack makes no noise.. just needs the 2x4 on top to get enough lift. For replacing the bumper jack in the trunk though, it's a nice small package, but just remember to pack a 2x4 block for spacing. to get enough lift.
I had to use a 2 x 4 on my 85 TC with one of those little jacks now that you mention it. Good save!
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
