As the title says, seeking a GOOD Air Bag Module for a 1993 Mercury Grand Marquis. The Part Number is F2AZ-14B056-A. Maybe Pete will see this?
1993 Mercury Grand Marquis Air Bag Module
If there was a code for a circuit failure and that's not been fixed, the new to you one will get bricked in about 5-10 seconds by blowing the thermal fuse. I've replaced the thermal fuse in mine twice already and found out the issue is either with the airbag itself or the clock spring. Neither of which can be got any more.
- Likes 1
Originally posted by sly View PostIf there was a code for a circuit failure and that's not been fixed, the new to you one will get bricked in about 5-10 seconds by blowing the thermal fuse. I've replaced the thermal fuse in mine twice already and found out the issue is either with the airbag itself or the clock spring. Neither of which can be got any more.What I Own: 1993 Mercury Grand Marquis GS
Originally posted by WagonMan View PostAll I can find in my stash of 92-97 parts are white modules. No Part#s on them. WagonManWhat I Own: 1993 Mercury Grand Marquis GS
Mine has code 51. Needs a new fuse and whatever is blowing it up fixed... so it's never getting that and eventually the airbag light will burn out. I could theoretically rebuild that one again (replace the fuse).
Originally posted by sly View PostMine has code 51. Needs a new fuse and whatever is blowing it up fixed... so it's never getting that and eventually the airbag light will burn out. I could theoretically rebuild that one again (replace the fuse).What I Own: 1993 Mercury Grand Marquis GS
The fuse is a thermal fuse. It requires some careful soldering (clips to work as heatsinks on the component side of the board). It's a bit of a PITA. Much easier to replace the caps. It's all through-hole stuff, so that part is pretty easy.
Originally posted by sly View PostThe fuse is a thermal fuse. It requires some careful soldering (clips to work as heatsinks on the component side of the board). It's a bit of a PITA. Much easier to replace the caps. It's all through-hole stuff, so that part is pretty easy.What I Own: 1993 Mercury Grand Marquis GS
Yes. Any short condition or too low resistance will heat up the power resistor that is clipped to the fuse and melt it to open the circuit. It's inside the little black and white box looking bit.
