Box brake pedal assembly
    Looking for a brake pedal assembly from a box panther. Would like to mod another one so I can have it ready, before doing my 5-speed swap.
    I'm guessing you'd prefer one from Canada to avoid international shipping charges?
      Indeed. But, if the price is right then, I can justify it. Its times like these that I with there were some boxes in the local yards.
        Will 90-91 work? There is a '90 out in my favorite yard that is missing the steering column (wonder where that went? ) Shouldn't be too hard to get to the brake pedal assembly. I'll stop there this weekend and see what's up if you want.
          Actually, im not even sure if the '90-'91 is the same. Wonder if it is made to fit the different steering column. Worst case, I will use mine and find a spare later
            Maybe someone who knows will chime in. Maybe go from there.
