im after any bracket you may have, prefer to keep A/C functional but not the biggest concern. everything else is a must. ideally i would like to drop my new engine in and have everything SOMEWHAT line up. like PS, A/C (if possible), anything you got or info you possess, im game to listen. thanks everyone!
Any and all bracketry for a panther 351
Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Alesha - Black 1982 Mercury Marquis - 255ci 178K, full custom Kenwood and Infinity system, lowered, dual exhaust, LED all the things
Tangerine Dream - Orange 1988 F-150 Custom - 300 i6 82k, Ghetto sound system, 5spd, 2WD, #farmtruckTags: None
the only brackets that are different on a 351 are the AC and maybe the alternator bracket. Everything else is a direct swap from a 302.
not sure exactly what you mean? like my 302 brackets swap over to this motor? does age make a difference, i have a 71 engineCharlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
AC bracket is 351w only.....alt bracket depends on whicj alt you plan on using (65/70 amp or 100 amp), I think everything else is the same, as far as panther brackets go....now what came on a 351w in 1971...who knows, I would compare what you have on the 351 to whats in your present car....
the timing cover bolt holes are in the same basic places for the water pump and damn near everything hangs off those bolts. The block and head mounting holes might be different, but I wouldn't be surprised if they're the same. I'd give it a shot and just see if the stuff will fit. Ford pretty much didn't change much, if anything, in regards to mounting points on the 302/351 windsor engines.
Originally posted by marquis_82_withneons View Postnot sure exactly what you mean? like my 302 brackets swap over to this motor? does age make a difference, i have a 71 engine
The a/c bracket is the different one.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
ahhhhh ok. i have the 255 currently which to my knowledge is the same as the 302 bolt on stuffs. i already have the 3g swap done. idealy id LIKE to have the a/c bracket if possible. not gonna hold my breathe though.Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
