60,000 miles -- what to get check/adjusted/replaced
    change your front 02 sensors too.
    2000 HPP Mods
    15.2 @ 89.13mph-1/4 mile
    9.73 @ 72.01mph-1/8 mile
      The 02 sensors are heated and are not recommended to be replaced until 100K or better. The only thing I would add to Scott's list would be a transmission FLUSH along with the filter kit and make sure they use genuine Mercon V as most shops will try to use an additive to make Dex III compatable which is junk.... Also, check the condition of the brake fluid, if it is not clear and looks medium to dark gray in color, flush that as well. Wouldn't want an emergency, high temp failure. Also check the throttle body for carbon build up as that can be a pre-cursor to FI problems in the future. Just my .02
      "Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
      www.myspace.com/nascarmechanic
        my rear pads currently have 126,000 miles on them. that 126,000 miles of police use and my hard driving. with 60,000 i bet yours still look brand new.
        I replaced my plugs and wires when i got the car at 86,000
