my 92 dies if i turn the a/c on normal and rev it and dies instantly if i turn it on max i just drove it for the first time of owning it in two weeks and it seems to drive fine pick up is good feels like it could be faster tho but im not really sure what its supposed to feel like
dies with a/c on
Does it die only while at an idle? Or can you kill it anytime while driving simply by turning the A/C on?
JayThese are highly engineered precision vehicles, the first step in diagnosing the problem is to strike the suspected offending part sharply and repeatedly with a blunt object, then re-test.
no... usually it won't engage well when it's failing... but if the compressor is trying to seize up, that would cause a big load. if the oxygen sensors are shot then the engine may not be running good enough to do much of anything either.
Definitely disconnect the power to the AC clutch and try switching things. If you have the same problems, it's not the AC.
that sounds more like an electrical load issue from the blower (weak alternator at low rpm) etc. Can't say for sure though. Might be a good idea to check electrical connections (especially to the ac/heater blower and ignition/charge systems). May also be getting weak spark (check plugs, wires, coils...).
bad IAC would be my guess. If its not opening the throttle up some at idle speeds, the extra load from the AC will stall the engine.86 Lincoln Town Car (Galactica).
I'd replace it. or unplug it. It may fail and stop the engine from running. And that's bad.
(Especially if you're in the middle of a 3100 mile road trip and it fails 30 miles west of Omaha,NE)
03 Mercury Marauder- 63k
check iac. that would be my guess1996 Mercury Grand Marquis - duals, PI cams, PI intake, J-Mod, MZT, BOC tune, 3.55s, 18in wheels
