not neccessarily, depends on the mods, or calibration, I run a 180 in every vic I have and still have heat in winter, cooler summer operation, and crap that you will have closed loop issues is garbage.
I find that the Mark runs better and does better on gas with those same mods (Autolite 103, actually). I'm not on the gas too much, better throttle response, and I gained 2 MPG.
The thermostat is fine but the plugs aren't necessary unless you have a different tune. Now if you get a steeda timing adjuster and crank it up then yes. See, 4.6 ain't all that bad. J-mod the tranny :evil:
