I have somewhat of a noobish question on replacing the main bearing bolts.
I went online looking at the ford parts site and when I search for main bearing bolts, 3 different ones come up.
These say side bolts so I assume these are the bolts that connect outside the engine block on either side of the main bearing cap.
these say cap stud so Im assuming that this is the one bolt with the stud coming out of it that connects to the spacer which connects to the oil pump pickup
These I assume are the main bearing cap bolts. they are sold in sets of 4.
Is everything I said correct?
Now i need 9 of the main bearing cap bolts and one of the studded ones is there a reason the ones I assume to be the main bearing cap bolts are sold in sets of 4 when only 9 are needed?
