hey all, 99 p71. The car exhibits extended cranking followed by a very very rough idle for a few seconds...only on startup though. Once it runs it runs well. It does this cold or warm.
CYcling the key on/off a few times fixes the problem.
Research has lead me to believe I have either a weak fuel pump or bad pressure relief valve in the tank.
So here is my question. Where is this relief valve? I can't seem to find much on it. Is it inside the fuel pump, or is it a seperate piece??
If it's a seperate piece then where can I find this item?
Also, I see cheap walbro pumps on ebay....I assume it would be no big deal to replace my oem pump with a slightly higher flow pump?? Car is stock right now,...
