VEHICLE: 1997 Mercury Grand Marquis, completely stock, mileage ~ 150K, great condition, well maintained.
BACKGROUND: Car used to be driven regularly, always performed well, then put into storage mode about a 1-1/2 years ago, started every two weeks while in storage, battery died last fall, so been jump starting every two weeks.
PROBLEM: Month or two ago noticed that if the throttle is opened slowly, everything is fine, but if the throttle is opened quickly there is a hesitation or stall, then the engine picks up and follows the throttle input. There is a clearly audible "PUFF!" sound that appears to be coming from inside the throttle body when the throttle is opened quickly. Installed new battery, but of course, that didn't solve the problem (starts a lot easier though!).
Other than this hesitation problem, the engine seems to be running perfectly (no miss or vibration or weird sounds). However, before I put the new battery in, I noticed that sometimes there was a type of puffing/rattling sound coming from the exhaust and the exhaust seemed to be hotter than normal and also once a faint rotten egg (sulfur) smell, which tells me that the engine was running really rich. Like I say, though, that went away with the new battery.
Any help would be greatly appreciated.
Also, would it be worth it to take the car to somebody with an engine analyzer to see if the system may be able to show some sort of diagnostic code?
I'm wondering if I may have damaged something from jump starting the car for so long -- maybe some sort of electronic sensor or valve or something
