As the title says I have a new misfire. My 1998 MGM with COP ignition has developed a misfire at higher rpms. This started suddenly on my drive home from work. It happens in every gear at the same point in the rpms and the car basically sounds like its running on 6 cylinders, I have no muffler on right now so it is easily heard when it starts accompanied by a sudden decrease in power output. Any ideas?
New misfire at 1/2 + throttle
sounds like one of the coils is dying. I would expect that a code scan should tell you which cylinder the misfire is on. Pull the coil out and make sure the hole isn't full of water or oil. if its good, try moving the coil somewhere else and see if the problem moves along with it.86 Lincoln Town Car (Galactica).
Hi Wannabep71
Can you access "Mode $06" on your scanner? You might need to go into Generic OBD, Global tests, On board diagnostics or some such to access Mode $06. If you can access mode $06 go to test $53 and it will tell you which cylinders are mis-firing even if there are no codes. A little toilet reading
Regards
DereckPresident and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
there's yer problem... maybe need a fuel filter change... check the fuel line for dents/kinks/leaks.
I think the pump comes out the front on those. Look above the diff at the plate on the tank. If that one has fuel lines, then you should be able to get the pump out without removing the tank.86 Lincoln Town Car (Galactica).
