Wanting to get a new set before winter, possibly wires. Pretty sure I have original ones and with 96,xxx on it i figure it's time to get some new ones. Suggestions on good brands/series? My grand marquis is an '02.
Spark plugs
AutoLite or Motorcraft. And if you want to spend some money, NGK's.
03 Mercury Marauder- 63k
I'd go with Motorcraft OEM's. Right plugs for the car and not expensive (or shouldn't be)!
2002 has coil on plug ignition. No wires to replace, just coil packs. If you're running okay, and getting decent fuel economy, no need to replace the coils just yet. OEM coils are about $52 each, there are aftermarket ones available through Rock Auto for $15/each, but a lot of people here poo-poo the aftermarket ones. I've not had any issue, replaced one coil with a cheapie one over a year ago, and it's still hitting strong. Maybe I got lucky?
2000 Mercury Grand Marquis GS HPP - SOLD
Wore out the cam chain tensioners and jumped time at 176k miles.
the "wires" are the coil "boots"... so yes, there are wires to check as it were.
My spark plugs crapped out at less than 96,000 miles, so ya, it's about that time. Once you get into misfire territory, you risk frying your coils. I hadn't heard of replaceable boots before, but I just looked into it, and they do indeed sell the boots separately. Here a link:
yes, the boots are replaceable. they just pull off of the coils.
motorcraft and dont look back. if you require platinum, get the fine wireCharlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Alesha - Black 1982 Mercury Marquis - 255ci 178K, full custom Kenwood and Infinity system, lowered, dual exhaust, LED all the things
Tangerine Dream - Orange 1988 F-150 Custom - 300 i6 82k, Ghetto sound system, 5spd, 2WD, #farmtruck
I heard the 97 + need platinum, double on the passenger side. I guess its cause of the waste spark gate system.
Would I be ok with just platinum (single)??"To Find yourself, you must first lose yourself"
-1973 Volkswagen Bus Westy
-1986 Honda Magna 700cc
-2011 Subaru Outback
Originally posted by porschpow View PostI heard the 97 + need platinum, double on the passenger side. I guess its cause of the waste spark gate system.
No Clue What THE FACOTRY Calls For. I don't have a manual
Some people here say copper, other say platinum, others say platinum and double platinum, lol
Dealers don't even have there computers go back to 1997 anymore"To Find yourself, you must first lose yourself"
Does the Ford Site go back that far for the manual? If not, I would check out OEM plugs on ROCKAUTO or a Ford Dealer site. How about the sticker under the hood? Is it still there? You could also check out EBAY for a OEM manual - I am sure someone has one for sale and it will always come in handy!!
I just got off the phone with the Lincoln mercury dealer near me. They said, the 97's require double platinum!!!!!"To Find yourself, you must first lose yourself"
